Ford Fiesta ST Fortune Auto 510 Series Coilovers
Harvick
New Fiesta ST coilovers by Fortune Auto
Price: $1699.99 - http://www.fortune-auto.com/
  • All shocks custom built to order
  • Track use only
  • Dyno tested
  • Dyno graph supplied with all four shocks
  • Amsoil synthetic shock oil
  • "Ultra" Digressive piston technology
  • Assembly certificate (documenting build & QC)
  • Radial bearing mount included (on mcphearson)
  • Spherical bearings
  • 24-step rebound adjustable dampers
  • Swift springs upgrade available
  • Mono-Tube damper with high pressure nitrogen
  • T6 6061 forged aluminum mounts & camber plates
  • Bright dip anodized
  • Height adjustment independent of preload
  • 5-year manufacturer's warranty (1 year on piston)
  • Rebuild-able
  • Revalve-able
  • Modularity - Upgradeable to 2-Way Canister
510 SERIES - GENERATION 5 UPDATES
Radial Bearing Upgrade
510 Series Generation 5 dampers now include our Koyo radial bearing upgrade as a standard option. Radial bearings provide less spring bind for noise free operation and smoother steering response.
Ultra Precise Shim Stacks
Shims are deflection disks that cover up the port holes on a piston. They regulate the fluid flow which generates the force found in a damper. "Valving" or "re-valving" of a shock is accomplished by using a variety of shims that will ultimately provide enough resistance and damping ability for a particular application. Minute differences in the shims' diameter and thickness are very critical; just a thousandths of an inch of variation in the dimensions can change a damper's force profile up to + or - 25%. The shims' consistency is crucial in matching shock absorbers to one another. Generation 5 dampers utilize a high-grade shim material made of Sandvik steel, ensuring precision matched dampers.
Lightweight Internal Floating Piston
The new Generation 5 Internal Floating Piston is considerably lighter and uses a low-drag teflon band that drastically reduces stiction. This allows the damper to react quicker to shock forces.
Brisbane
I asked Fortune via their Facebook page and they told me that they no longer do these due to insufficient sales :(
