First oil change and 4.3 Quarts put me above the Max line..
Port Hueneme
Did my first oil change at 5k and afterwards I noticed on my oil dipstick that the engine was slightly overfilled, about 1/2 an inch past the full mark. I did a search and it seems that this has been seen before. I have a 2015 with the updated dipstick and after draining approximately 1/2 a quart I am right at the Max mark.
Seems to be that 4 quarts should put me right at the max line on my dipstick for future oil changes.
Anyone else experience this?
Colorado Springs
When you changed the filter, it's supposed to be 4.3 quarts. Since I'm guessing you changed the filter, it's weird that it would still be more. I noticed mine was slightly over the MAX mark when I took it to the dealer to get it changed. So now I will just put 4 quarts and add if necessary.
M
Port Hueneme
That's what I plan on doing in the future. 4 quarts and top off if needed.
M
Port Hueneme
Yes. Drove it for about 2 days/45 miles. Shut the car down for 10 minutes and checked it.
Hijinx
U.S. Air Force Veteran
Auburn, AL, USA
Not be an alarmist, but be on the look out for a failing turbo seal. I had that happen after a quick lube joint filled me up like that. I don't know how many times it takes to hurt... For me, it was about 12000 miles or on the third change before I noticed the puffs of blue smoke out of the exhaust and oil residue on the tips. After that I started doing my own changes, and 4 quarts is it every time.
Again, I cannot stress enough that you SHOULD NOT be overly concerned; simply aware. The cause would be that when overfilled the turbo cannot drain properly.
Scent from Glade Air Freshener
OffTheWall503
Memphis, TN
Another reason why I change the oil when the engine is warm and let it drain for at least 20 minutes. But it also helps that I work at a shop with lift and tool access. [biggrin]
Silly question, but is your car parked on flat ground when you are checking the oil level?
Mesa
Yeah 4.3 quarts is a tad too much, if you get your oil in one of those 5 quart "easy pour" jugs it's easy to overfill.
M
Port Hueneme
Checking it in my garage. I used a lift and I let it drain for 20 minutes. I used a 5 quart jug and filled to the 4 quart mark and then added 1 cup of oil which was approx. 03 quarts. Next time I'll use 4 quarts. Thanks for all the feedback. After draining about half a quart the dipstick reads right at the Max line.
JTP
Los Angeles
I like to fill it about 4 and then start it up and check after. Its easier to add than to take oil out but 4 seems to be the magic number.
