My gut feeling is that it’d be a waste of money/time, but could be worth the certainty. I’d say I’m 99% sure it wouldn’t help much. Other platforms may have their stuff figured out, but I think it’s still comparing Fuji apples to Honey Crisp apples. Slightly different technologies, fueling strategies, cam profiles, ECU architectures, etc etc etc...
Plain and simple, the HPFP becomes a problem before the LPFP becomes a problem. But, maybe the community has just been traveling down the road of a mistake made long ago?
I have questions for you, though. If you’re convinced, why don’t you do it? If you knew all of this why did you buy aux fuel?
That and a deal on a AUX came along. I actually bidded on a ZZP injector controller on eBay but got sniped with 5sec left, lol. And while meth injection would do the job, it’s too much hassle to have a tank to fill and check all the time. I looked at buying a meth controller that can control a Fast acting valve and use methanol injectors ( basically I was going to use the LPFP line like an aux fuel, the variable flow FAV and two solenoids. One solenoid would open at 4500rpm and feed the FaV, and the second solenoid would open at 6,000rpm and by-pass the FAV for full flow to a 2nd meth nozzle. All said and done, it was going to cost about $550-$600. I bought the aux fuel for $500.
ZZP also talked a bit about the MPFI would actually be “not as good” as a single injector for certain setups. The injector Pulse Width can only be so fast. Long story short, 4 injectors would end up injecting too much too fast and you can’t slow it down anymore. Of course, the MPFI pays huge dividends on the high HP end of things. But if your only needing a little bump in fuel, 1 small injector is great.
Unfortunately for me, I don’t have access to a lift or anyone with a lift. I guess if I had no choice, like a bad fuel pump, I’d make it happen in the driveway. But that’s not my case.
But if I was one of the 100’s of people with a hybrid, right at that 300~ hp area, I’d def be interested. The 5th injector might be a waste of $900 to fuel an extra 25-35hp.
Issac you have any interest in the G25-550 ?
