rodmoe
wausau
Well then most any 17x7 , 47mm offset, 4x108 wheel should work with a 204/40/17 inch tire..
The older SVT focus rims fit or a less expensive after market would fit in a pinch.
If you want a real Ford factory rim I am sure they can be had just not as cost effective..
rooSTer
Miami
I want a true spare for the garage so when I get a flat I can switch it whilst the flat gets repaired or replaced. I don't want to be riding on a space saver for any longer than necessary. Experience has shown me it can take a few days to get the full sized wheel repaired / replaced.
In the US, the wheel (part# C1BZ-1007-G) sells for $199.77each...you might be able to find them a little bit cheaper online
New York
Hi, I just picked up my ST and I've been thinking about buying some wheels. I wanted to know if 17x9 would fit on the car and would I need spacers??
MKVIIST
Congratulations! I would not recommend 17x9 to be honest. I have 17x8 and it's pretty wide.
New York
I'm looking at a wheel thats 17x7 and its has a 25 offset. Would i need spacers, would it be fine as it is or would it be too much?
MKVIIST
Its cutting it real close, I'm at 38mm right now and its flushed, 13mm = 0.5 inch. Granted I'm 1" wider at 17x8, it might end up being flush like mine. What wheels are you getting?
Here's a good tool you can use http://www.willtheyfit.com
Ottawa
#31
I don't understand the 195/45R16 recommendation. Any tire/wheel calculator will tell you that 195/50R16 is a more precise match (i.e. closer to the original wheel diameter). The manual says 195/45R16 to allow clearance for chains in winter, but I don't intend to ever install chains. I'm likely going to go with 195/50R16 for winters...
iso100
#32
OP, really should add hub bore diameter to the first post.
dyn085
Vancouver
#33
Just a little heads up! The day any of you even think about "stancing" an ST... Sell it... Sell it straight away and leave it for those who want a fully functional ST. :)
I guess you can add me to the list of people that should sell their car based on your opinions as opposed to my own wants/needs.
There's no reason not to install the 50 aspect ratio if you don't plan on using or will never need chains.
63.4mm
Ottawa
#35
Has anyone tried Focus OEM rims for winter tires? I'm considering getting them for winter tires, 15x6.5 ET 42 prob.
rodmoe
wausau
#36
Have not tried those wheel but I run 15's for track and for winter snow tires they should work great and they look good too ;)
dyn085
Vancouver
#40
You won't notice too much of a difference without a drastic offset change. Maybe a fractional amount of lateral grip and stability, but the majority of that is dependent on your alignment.
