I think NGK LTR7IX is the wrong plug for own Ecoboost engine fellas. I brought a set and noticed a difference in the centre electrode design.
I ran the plugs anyway but I notice it was a little harder to start from cold and run on 3 cylinders sometimes for a few seconds.
The OEM plug have a projected centre electrode, these do not. Link to NGK, http://www.ngk.com.au/spark-plugs/technical-information/projection
Image I took so you can see what I mean. OEM plug on the left.
It looks like you are right about it being the wrong plug for these engines. I emailed NGK and got an answer from them. The response is below...
Hello,
Thank you for your inquiry, however we currently do not have a heat range colder replacement for this spark plug that is quite the exact fit. The original spark plug for this application uses an extended thread shell that part number LTR7IX-11 does not have. The use of the non-extended thread shell can lead to issues with deposit build up on the spark plug that can increase chances of fouling and the possibility of hot spots for pre-ignition.
Regards,
Rob MacDonald
Technical & Training Specialist
NGK Spark Plugs U.S.A. INC. || http://www.ngksparkplugs.com
46929 Magellan Dr. || Wixom, MI 48393
OFFICE: 248-926-7104
