Fiesta ST Intercooler Info Thread
Seattle
I don't think Mountune invented tube and fin. I also know they have been building Racing turbo engines for a long time. Mountune had a choice to make and CHOSE tube and fin and give detailed info on why. Why when they can choose either do you think they chose the more expensive core type if it did not work better? What motive would there be to choose a lower performance type? The tech info seems to make sense. Can you give details as to why "almost all power cars use bar and plate" beside the reason of it being cheaper? I am curious where Mountune went wrong technically in your opinion. What makes bar and plate better?
+1 Seriously [popcorn]
Personally, at this point, I do not care which one is more efficient by a few degrees or so of cold side charge air temp on the factory snail setup (with or without a tune), since pretty much ALL of them (whether tube and fin, OR bar and plate) are going to be better than the factory IC, in both one hard all-out pull, and continuous repeated hard driving. ;)
I just do NOT want to HAVE TO change out the radiator to one of the aftermarket ones RIGHT NOW in order to not be overheating due to not enough frontal air flowing through the IC core to said radiator. [nono]
Hopefully, what re-rx7 said about most of the coolant cooling being done by the TOP, fully exposed portion of the radiator is the reality in this case, (and WHY I refuse to block it even a tiny little bit with all of the add-on 'accessories' so many do behind the grille on these cars). ;)
Oklahoma City
MANY on here do this, but, it is usually those with at least the DHM tubular crash bar installed, (if not their Race IC as well) doing this mod BECAUSE they are the only ones who could actually see any cooling benefit from it, due to them not having the factory crash bar blocking the whole section which is covered by the un-modded grille. ;)
I never really looked too hard at it because I didn't think I needed it. Thanks for the clarification.
Sent from my Nexus 6P using Tapatalk
re-rx7
Ardmore
You really need to read the link i posted. Hint it was made by Spearco. Tube and fin is cheaper. Randy is talking out of his ass.
re-rx7
Ardmore
http://www.superstreetonline.com/how-to/engine/0304-turp-intercooler/
Tube And Fin
"A conventional tube-and-fin intercooler weighs less than a bar-and-plate design," says Wang. "Typical tube-and-fin units utilize extruded tubes with fins pressed into place. In order to achieve strength, a thick, extruded tube must be used.
"The tube-and-fin core is held together and its seal is created at the joints at the end of the plates, which is usually .125 inches thick. The width of the tubes is less than the width of the side plate. Space is lost where the joints for sealing are used. So a 3.5-inch core will have tubes only 2.87 inches wide."
Unable to maneuver around the machinery, Wang continued, "Also, fin design in the charge side, inside the extruded tubes, was limited by the extrusion machine, which impeded the design of charge side fin geometry to meet individual custom applications. While this design did allow varying ambient fin designs, the charge air shortcomings proved too much of a handicap.
"Tube and fin has a larger leakage rate compared to bar-and-plate cores. Furthermore, tube-and-fin cores are more susceptible to road damage from rocks and debris than bar-and-plate cores; big trouble in front-mount applications. The oval tubes are extruded from thin-wall material and any sort of extreme pressure can cause these tubes to 'balloon.' In today's high-performance industry, high boost levels are the key power."
Bar And Plate
Wang had a more upbeat tone when it came to bar-and-plate construction. "Spearco pioneered bar-and-plate core design. True, the bar-and-plate design is a bit heavier than tube and fin, but this is actually advantageous.
"The core acts as a heat sink. Its ability to soak up more heat is especially useful in stop-and-go traffic. It keeps the charge relatively cool, then is able to dissipate the heat once the vehicle is in motion. Tube-and-fin units can't pull this off.
"A bar-and-plate core can take the damage of front-mount life and endure high boost without flinching. Sealing is superior in bar-and-plate units because the bars and brazing sheets run the length of the unit, providing a 100-percent seal between the ambient and charge sides.
"A key advantage of bar and plate is its extraordinary variety of fin designs on both sides of the cooler. Further, the height of the passages can be changed by using taller bars and fins, which dramatically expands the possibilities for the intercooler designer. A 3.5-inch thick core gets a 3.5-inch row of fins, not the 2.87 inches found in tube-and-fin designs.
"Also, a tube-and-fin design has a lot of room between rows where a bar-and-plate unit can get more rows into a given area with more area per passage which means more cfm and a more efficient unit. As far as big boost goes, the ability of a bar-and-plate core to handle high boost is determined by the thickness of the braze sheets, fins, side bars and top plates."
Spearco produces both tube-and-fin and bar-and-plate intercoolers. With bar and plate being so superior, one has to wonder why. It's all about cost. The tube-and-fin core is much cheaper to produce and is often used in OE applications, which inherently run lower boost levels.
Spearco put a new twist on tube-and-fin cores with its extruded tube design that incorporated the fins as part of the extrusion. In this design, the overall weight was about equal to a bar-and-plate core. tube-and-fin units are cheaper to manufacture.
Seattle
Actually that is Ken @ Mountune that originally posted that quote. I have a feeling you're not an engineer that designs racing products, so when someone that works at a company that works directly with FORD posts something based on actual research you should listen instead of just finding an article posted back in 2003 from an editor of a magazine.
Another quote from the same thread Ken @ Mountune:
Link: http://fiestast.net/threads/intercoolers-which-is-better-black-or-silver-tube-fin-or-bar-plate.2021/page-2
To expand on my previous post, I assumed the question that started the thread was referring to the specific application , the Fiesta ST since this is a Fiesta ST forum and not a debate about the merits of tube and fin vs bar and plate.
For the particular application and overall performance, we have found that a tube and fin performs optimally better when you consider air flow requirements for the other heat exchangers in the cooling pack. Additionally continued heat transfer is good compared to typical bar and plate designs that can quickly become heat soaked. As I mentioned, bar and plate type do perform well on short term applications such as a dyno pull. Modern cars have far greater cooling needs than cars of 5 and 10 years ago. Engines run at higher operating temperatures and frontal air inlet areas have become smaller. This makes the requirement for air flow even greater and was just one of the factors that lead us to use the type of core we did. So to be clear, yes bar and plate do cool charge air temps very well but there is much more to consider in this particular application. Cheers-Ken
re-rx7
Ardmore
That is exactly why Mountune talks out of their ass. Call one of the them up and see if they can answer a question about Wg, WGDC, Flow rates. They can't. Randy also made a post about making 240whp on 93 on stock turbo. Seriously? We are to believe that horseshit?
Yes, I posted an Article from Spearco. They produce both types of IC cores and prefer the Bar and Plate for obvious reasons. OE uses it to pinch pennies. Stock turbo will it work? Maybe, but a bar and plate will do much better. I live in a hot and humid climate not Seattle. No overheating here nor even close. Never get above 200 even going 85mph in 100+ heat. So the fiesta cooling system is different than other cars? Most of the cooling is done through the top opening. You wanna listen to good ole randy be my guest. Me, I'll stick with what top tuners recommend.
P.s razorlab asked for data. Randy never responded. LOL
stpaul/mpls
gee whiz. get a pair of rhino ramps and a 1/4 socket set. pull the freaking bumper cover off and stick the darn thing in there. then go drive it. then you will know if it is gonna run hot. or not.
btw went for a extended 10 to 12hr ride today with the cpe. 3 degrees over outside temps was the norm.
jmrtsus
Ooltewah
You have personal issues with Randy, that is obvious. I don't think Randy is a mechanical design engineer nor do I think he designed the FMIC or made the core decisions and he has a full time job other than the forum. I am pretty sure that the FMIC was done in the UK. So the problem is they have research and testing facts and you have issues with Randy.
I have had a few conversations with Randy, I know he knows a lot more than I do about our cars. You keep harping about 240 WHP like it is the Mount Everest of the stock turbo. Why? I know he does not strike me as stupid enough to jeopardise his job by lying about something like 240 WHP. 240 WHP does not sound impossible if you get 230 at the FW with a mild tune I feel sure with the right changes it can be done. As he is a Mountune Rep on this forum I have zero reason to not believe he knows what he is talking about and has both the parts and facilities to back it up, and zero to gain by lying.
As to the IC, referring people to a very old link having nothing to do with our cars yet backs up Mountunes heat soak statements is not a convincing argument. Facts I believe, animosity causes me to disbelieve. Since Ford allows only the Mountune FMIC as warranty friendly I guess they are not as smart as the "top tuners" either. I agree with Mountune that the so called "cooling" issues seem to be modded cars that change the airflow to the radiator. I will stick with Mountune and Fords opinion that more air flow through the core is superior for street cooling. My performance driving is for long periods of time on the streets and not a dyno run or a single race. I drive in the real world of mountains, valleys, curves and stop and go traffic plus the occasional 90mph for hundreds of miles in the desert or the Dakota's.
re-rx7
Ardmore
OK, given, but, does he have a point about the sustained power capabilities of the tube and fin design, due to NOT heat soaking like bar and plate setups?
When you say "power cars", are you talking about drag race/dyno/street race scenarios where one hard blast is enough, heat soak AFTER that be damned, or sustained hard use, like on a road course, or mountain driving/etc.?
Also, he is correct about the 'flow through' to the radiator being better on the tube and fin ICs, than on the bar and plate deals, no?
I am NOT defending one over the other, in fact, I actually HOPE you are correct since I have a brand new, still in box, uninstalled cp-e IC sitting in my basement, and I seriously want to know what is what BEFORE I either install it, OR sell it, and install the largest drop-in, factory fit tube and fin i can find. ;)
The choice is up to you.
But keep this in mind, I think if Mountune engineering thought that a bar and plate was superior for the car's existing design they would have used one.
Well then have at it. LOL if ford cared about performance and not penny pinching they would have made the ic with cast ends not plastic. 230whp on 93? LOL you have just proven the knowledge set you have. Im done.
re-rx7
Ardmore
Well then have at it. LOL if ford cared about performance and not penny pinching they would have made the ic with cast ends not plastic. Ford allows them the warranty because it cant make alot of power. No one is changing airflow to the damn radiator. IT's all done through the top. Keep believing the shit mountune spews. I just took my car on a 1k mile roadtrip in 100degree weather. Guess what....IC temps never changed cruising. 240whp the everest? How about the moon? 230whp on 93? LOL you have just proven the knowledge set you have. Im done.
P.s before you question my opinion of Mountune look at my signature.
Seattle
LOL you are getting silly. This is a fiesta...penny pinching allows you to buy the car at the price you did. I think you should throw away your Mountune MRX due to their lack of good engineering...since Mountune obviously doesn't know anything. And BTW that was KEN...I'll say it again KEN that posted the comments in the thread I posted earlier...as I stated in my earlier posts. The only thing you have proven is that you cannot read. You are right, you are done now.
re-rx7
Ardmore
Believe me I've thought about it. Have you not read the mrx thread? It needs a stronger gate, not holding boost up top ect. Then guess what? They all of a sudden offer a better wastegate. Lol gtfoh. Keep sucking the mountune titty noob
P.s. A recent addition to the forum with 17post.
Seattle
30 posts now [cheers]
jmrtsus
Ooltewah
Before anyone respects your "signature" you should first attend some reading classes.......trying to argue a point when you cannot read/comprehend is a losing battle....we are glad you are "done". Actually you were "done" before you started. You lack of knowledge of this car/engine is epic. Let me help your reading difficulties, where did you read Ford designed the IC?Ford did not design the Mountune FMIC....wow.....just wow. Just because you do not have the parts and facilities to do what Mountune has done just means they can do things you can't. Is that your problem with Mountune? They can do things you can't? Thank you for your input, we all got laughs from it!. At least now you know Ford does not own nor design for Mountune don't you? Isn't learning a wonderful thing?
re-rx7
Ardmore
Now this is hilarious. Mountune designs a shitty undersized ic that can't keep charge temps down with any kind of power and people jump in to defend it. The attempt at trolling is hilarious and amateur at best. lol where did I say ford designed the mountune fmic? I stated " if ford cared about performance and not penny pinching they would have made the ic with cast ends not plastic" as in ford IC...the stock one. Lol come on you can do better slick.
Btw I've yet to see any knowledge you have on the engine or anything on this car. Enlighten us. Since you know so much about mountune, how about getting the compressor maps for the turbo. Better yet, call and ask since they know all. I'll wait.
GAbOS
Guys.. re-rx7 has some good points, but unfortunately his nearly valid points are beaten to death by his inability to keep his mouth shut. Just let him talk himself to boredom.
