Ok, looking at the picture again I can see it looks like 3" piping, I do not like how it is necked down, not a good way to do it. On mine I fit the pipe all the way into the turbo side of the flange, welded it on the other side of the flange, then used a small ball peen hammer to flare it to the opening size which is closer to 3.5 and used a die grinder to smooth it. That in effect is necked down but in a better flowing way.
Wrapping helps a great deal with heat under the hood and near the shifter cables, etc....
I also covered the brake lines, cables, steering rack, and other parts with either fiberglass fabric/foil or fiberglass mat/foil heat wrap material.
My intake is also wrapped with the fabric foil, then fiberglass mat foil and again with the fabric foil.
Next I am looking for a blanket for the EFR turbo, only one found so far is $219, ouch!
