Just H&R springs at the moment, will hopefully be switching to the KW ST's in the next month or so.
I just had 4 Michelin Pilot sport 3's fitted and they do seem to rub quite bad on the front, rears are fine.
I previously had the factory fitted Bridgestones and they was fine, i think the Michelins have a squarer shape to them, the sidewalls certainly look taller unless thats purely down to the fact that they are new tyres so in theory they are 6-8mm taller than the worn ones they replaced.
The Sparco wheels have a different offset to the stock wheels so that makes them stick out more, plus I'm running 15mm H&R spacers which have been put on a lathe and reduced to 13mm buy a friend that works at Ford's research centre just a mile down the road.
The top two photos are with the 13mm spacers, the bottom two are with 5mm spacers
