FearTheSnail's ST
I now have another block. Came off another member's car who crashed his car back in April of 2017(believe that was the date). Has a Spec Stage 3 clutch + aluminum flywheel, and good transmission.
How much was that setup?
Philadelphia
I’d have to drive one with a 67r to convince me to be patient with the lag. But that’s damn impressive.
Idk if we are looking at the same graph. Cause from what I can see on the graph he's making more torque at 3k rpm then some of us with hybrid turbos. At 3k rpm I see roughly 280ftlb of torque.
Idk maybe I'm seeing things.
Dallas
That’s for the 60r pull. I’m referring to the 67r pull (red graph).
Rittman
From June of 2015 until March of 2018 I was on the Gen 1 GTX2867r with .63ar tial exhaust housing. The Gen 1 GTX2860r with .52ar tial exhaust housing from March 2018 on. The 2867 was on an e50 mix of 91 octane and e85. The 2860 so far I have only ran straight 91 on. The 2860 with .52 is by far the better turbo for this car. With the power numbers that I posted above the wastegate dutycycle on the 2860 is still under 30%. There is a lot left in the turbo I just need e85 or another fuel type again. I plan on running 91 and methanol. I moved in May of 2017 and no longer have access to e85.
Do you need anything other than a tune and upgraded fuel pump for E85 or do you need injectors and lines and all that other [emoji90]?
Sent from my Pixel 2 XL using Tapatalk
jeff
Evans
On your new engine? Dang man sorry to hear. Are you done or not? Details....
