Factory spark plugs out at 630 miles - Comparison to Tune+ Denso plugs
LilPartyBox
NYC
OK, how much should I screw them in?....
This is always a bit scary. I don't trust torque wrenches at anything below 30 ft lbs. So I tighten until snug. That means until the first sign of resistance ending when using light pressure...Then from that point I go another 1/2 to 3/4 turn and leave it. Then I check it all again a few days later just to be safe. Rarely do I have to re-tighten.
We have aluminum heads. Using antiseize decreases the amount of friction between the threads. The result of the lowered friction is that when the spark plug is torqued to the proper specification, the spark plug is turned too far into the cylinder head. Most manufacturers don't recommend antiseize on spark plug threads. It can act against you when removing them sometimes also. As we all know it's hard to compress a liquid so in all reality you're doing the same with antiseize. Thus throwing off torque specs if you want to get technical. You have no feel with a tool vs. Using a piece of hose to help you start a spark plug into its home. When the plug meets the threads and goes in its home the hose will simply spin off the porcelain and you can pull it right off. This decreases the chances of cross threading into aluminum which is a soft metal ...especially when it gets hot. This is the reason you don't take drain plugs out of aluminum oil pans after it just came off the road to get its oil changed due to the fact you don't know what shade tree turkey neck mechanic worked on it last and reefed/ over tightened the oil drain plug. Then again WTF do I know I'm only an ASE Tech who's seen alot of people put square pegs into round holes. There's the right way to do things and there is the corner cutting shade tree garage way. It's not a hard job....if you have questions ask. It's like I've always said there are no such thing as stupid questions ....only stupid people who don't ask them and think/claim they "know " what they are doing.[thumb]
LilPartyBox
NYC
I've seen a few instances first hand where anti-sieze wasn't used. in one instance, years later when removing the plugs two of them fused with the head. my neighbor found that out the hard way when the threads from the head itself came out with the plugs. That was on a Nissan Altima.
Dissimilar metals have the tendency to fuse together over time. coating one side of the threads using a pinky nail sized dab of anti-sieze on each plug is all it takes to prevent it. I said a "light" coating, not cover the entire thread with the stuff. That would indeed effect the "feel" and could absolutely lead to over tightening and also get messy. but doing nothing could absolutely lead to a damaged head.
...You have no feel with a tool vs. Using a piece of hose to help you start a spark plug into its home. When the plug meets the threads and goes in its home the hose will simply spin off the porcelain and you can pull it right off. This decreases the chances of cross threading into aluminum which is a soft metal ...especially when it gets hot...Then again WTF do I know I'm only an ASE Tech who's seen alot of people put square pegs into round holes.
Why would there be a chance of cross-threading a plug into hot aluminum? As i read it, it sounds like ur implying changing plugs on a hot engine. Plugs should only be changed on a stone cold engine or risk damaging the head, among other risks.
Also, the spark plug tool obviously has feel. I would argue it has way more feel. I can tell exactly when the threads start and if the plug thread is perpedicalur to the head. It also allows one to be accurate and consistent across plugs because, u know, it's an actual tool. A piece of hose...just some piece of hose? You can't seat the plug perfectly each time in a hose. It's not any kind of accurate or consistent. It's a hose not a tool. "simply spin off the porcelain" is just a bit vague, no?
So what kind of hose are you "hosers" (j/k lol) recommending? A red one? A green one? Rubber or vinyl? What diameter? home depot or lowes?[biggrin]
