Thanks for the info, do you happen to know the PSI rating of the check valve? And did you have to do anything to prevent vacuum from forming in the fuel tank as fuel is used?
Factory manual shows three hoses going to the EVAP canister but doesn't say what each of the lines do. I imagine one is from the fuel tank and other goes to the engine bay, but what about the third line? Does the
I'm thinking the check valve should go by the arrow with "x2" on it.
This is a generic EVAP system diagram. It doesn't show the third hose for the canister...
