Ethanol vs. Water Methanol Injection
Tehachapi
I am looking to get a few more HP out of the stock turbo, running full Stg 3 OTS cobb currently.
What are the differences that you would see between running, say, a E30 or E45 blend, or using a Meth injection system such as the Devils Own Stg 2 kit( boost controlled)?
They would both boost octane levels in the fuel, and allow you to run more boost/timing. Right off the bat you have a much larger investment for the Meth setup, plus the on going cost and hassle of filling the the Meth tank. On the other hand the closest ethanol station is in LA county past Palmdale, so quite a drive.
You are going to get a custom tune for either in order to take advantage of the benefits provided.
Differences? Pro's Con's? Preference?
Cobbs on the fly map changing makes switching tunes so easy, this doesn't have to be an 'always on' solution.
I have only ran meth/water and that was quite a few years back, my main issue was finding supplies, having it run out at the wrong time, carrying extra around.....
Just last week I talked to a race shop manager that said he has seen far to many issues with valves going bad, engines hydro locked, so never uses anymore.
Just passing on my experiences and what a pro in charge of a big race shop related to me.
My understanding is they are not for fuel so much as for cooling the intake charge so you can run more boost, if that is the case then it might not do much for you but again, that is related to meth/water injection.
I am sure there are others here with advice to help you work this out.
Sourskittle
Lakeland
I can speak from experience on both sides of the fence on this one...
My SRT4 used a combo ( not in this order, all the time) 24.5psi of boost, race gas, pump gas, 100% meth injection, 100shot of nitrous. It was quiet a chemistry set...
I'm going to say the Ethanol has a higher output gain, as well as less chance for failure. Fact is... Meth injection parts are made of...... Parts. And parts fail sometimes. If your tuning the motor hard enough to see gains close to what E45 can offer, your really pushing the meth stuff hard and trusting it with a TON of your fuel needs. If an injector clogs, if a check valve sticks, if a line busts, fit a fitting breaks, if a motor fails, if a regulator by-passes, if a fuse pops, if a processes burns, if a wire tap loses connection, if a motor/ pump mounting bolt breaks, if a reservoir leaks, if a blend is off.... Any of those issues could, can, and do happen. And if your counting on alcoy injection to support your tune (more boost or more timing or adding fuel or all of those), and it does from 100% to 0% in the blink of an eye.. Its could be very very bad.
Besides availability, Eth only has two other draw backs... #1 on my list is that sticker on the pump that says, "at least 70% ethanol". Ok... 70% to 85% is a good difference. #2 pump wear. By running E30-E50, you've taken car of the pump wear issue. Razor is currently building a solution for us right now that will read the % of ethanol in the fuel line real time, so that pretty much also eliminates issue #1. Availability isn't going to change, and even still, I'd want E85 and/of a mix of it in my water/meth injection tank anyway, so they are even on that scale to me.
So if i had to pick one or the other, and not both.... I'd pick E45.
I used devilsown meth injection kit for years. They replaced 2 pumps for me, for free. They replaced 3 check valves for me, for free. The 4th check valve was a new improved version that was less likely to fail. I installed it while my motor was out of my srt4 getting a new short block, ported head, cams, and newest upgrade in super stock turbo tech. I was breaking the motor in, and had 400 miles on it, when I decided to run some windshield fluid through the pump to make sure the last batch of meth didn 't kill it ( again ). And to make sure the pump wiring engaged and worked like it did before. I put 2 quarts in the tank and drove to work on 6psi peak. Pump worked, controller worked, everything was good, so I stayed out of boost on my way to work and worked for 10 hours on Thanksgiving eve. As I left work at 2am, I started the car and it was "cammed" harder than it seemed like it had before... I figured, "well... Its cold, its got big cams, ported head, and 680cc injectors, that's gonna happen". I pulled out of the parking spot and the car slammed to a stop. I thought I just stalled the aggressive clutch. Hit the starter and it just clicked. I figured my battery was some how dead. Checked the battery with a volt meter. Got to thinking about it, and reached under the front bumper and pulled a charge pipe loose, and nearly 2 quarts of fluid poured onto my arm.... Tried to move the engine with a breaker bar , but it was seized. The check valve had failed for the zillionth time, and filled the huge intercooler up while I was working.
It bend every rod and twisted one so bad it hit the block and broke a piece off. A 400 mile, brand new engine, hydro locked.
That horror story being what it is... I would/will be using meth injection again. This time, I don't care what happens, I'll mount the injector higher than the tank. I also, like before, will only be using it as a knock deterrent, intake/valve cleaner, and charge air temp cooler. I will not rely on it for any forum of fuel or boost ( maybe a bit of timing via the ecu per the intake air temp ). If the system fails, worst that happens is that I got slower and I have to mail something off for warranty.
Ethanol is fairly fool proof. Ask a good tuner for a E40tune, and only run it with E 40 (or so) fuel.
I plan to run both. I loved see my charge temps cooler than abundant with 24.5psi from a tiny stock/modded srt4 turbo. And it had a big part in make 354whp and 407TQ on the stock intercooler.
razorlab
Bay Area
I surprisingly agree with everything Skittlez said, minus using meth injection again.
M
Tehachapi
Thanks for the input guys. You brought up some issues I hadn't thought about with potential risk involved with meth injection. Ethanol for certain sounds considerably better. I would be curious to know if Willow Springs raceway has any fuel on site, as its only ten minutes from my work.
Sourskittle
Lakeland
Last time I was at Sebring they didn't have E85. But its been a while. Actually... All there gas was E0
M
Tehachapi
I had the day off, went down to the track(willow springs), very cool place, but they only had 93, 100, and 110 octance race fuels. Since I was there, I put in 3 gallons of 100 octane for only $30. So its not an option. Unless VP fuels in Lancaster has any E fuel, I'm SOL. The fiesta REALLY likes the higher octane stuff, even on the Cobb OTS stage 3 I could tell a difference in how the power came on.
