Electrical issue - speedometer dies, radio shuts off, ABS light kicks on
Star, ID
Quick background on the car:
2015 - upgraded intake, charge pipe, intercooler, BOV. I bought the car 4 months ago with mods already installed. Previous owner had a Dizzy tune although I'm pretty sure he took it off (i bought from a dealer so i dont have PO's direct contact to ask the questions). I've been running 87 octane with no issues or detonation.
I need some help troubleshooting. Here goes:
2 days ago I was cruising on the freeway when my radio shut off. After a couple seconds it turned itself back on. I thought I was crazy at first. Then it did it again and again. I figured sync was just glitching.
Next day I'm driving and it does it again. Now I'm getting irritated. Only right as I get mad at the radio the speedometer dies 10 mph and the ABS, brake, and traction control lights all come on. This happens for no more than a second and then things are back to normal. At first it only did it a few times and would stop for a while. Now it's happening consistently. I've also found at idle you can see the lights flickering sometimes (I only notice it when it's dark outside).
I've found that if I keep the RPM's under 2k the problem mostly stays away. When i rev it up that's when the problem happens very consistently.
I read on a previous post about a similar issue being a bad alternator. So I hooked up the volt meter and I thought I had the problem identified. The voltage would sit at 13.05 and not move at all regardless of revving the engine. All the sudden it would kick up to 14+ bolts randomly then just as quick back to 13.05. I'm used to seeing alternators voltage fluctuate with the engine speed so I thought I had her licked.
Bought a motorcraft alternator and installed it tonight. Took it for a test drive and the exact same problem came back after a couple mins of driving.
Checked voltage and a similar thing is happening. 12.97v sitting there. I revved it up and the voltage stayed the same. It would randomly kick up to 14+ and then settle right back to 12.97 where it stayed for the most part.
I really thought the alternator was the problem considering when I'm revving above 2k rpm the problem consistently happens. Under 2k rpm it almost never happens.
Thought?
LostInTransit
U.S. Coast Guard Veteran
North Eastern USA
Your battery can't hold a charge anymore. best upgrade to another battery. it's a known issue that the FoMoCo/motorcraft batteries have a shortened lifespan. as a side note changing the battery will also allow you to clean the terminals and check the ground.
