Electrical Gremlins
Burlington
So last night I was swapping out the drivers side motor mount and of course had to pull the battery and battery tray which I've done several times before however this time once everything was reassembled the car would not start or even crank. I plugged in the AP and read the following codes...
P0001
P007D
P0113
P0118
P0122
P0223
P06E9
P26BD
None of these codes showed before so I figured it was missed connection or loose ground cable. After double and triple checking everything that doesn't appear to be the case. Next I thought maybe a fuse or a relay. All the fuses looked good so short of replacing every relay I'm not sure what to do. Maybe it could be the PCM since there are so many unrelated codes. Not sure. Any other ideas or suggestions. Cheers.
