I recently installed the 25mm Eibach front sway bar and included bushings on my 17. I did not have to remove the subframe, but I did have to remove the 4 main bolts: two at the rear, and two that you reach through the hole in the lower control arm. The subframe then hung from the LCAs, and I accessed the sway bar mounts from the rear of the subframe. With some downward pressure on the rear of the subframe and upward pressure on the exhaust flex pipe, I was able to get the OEM bar out. And with a a little more pressure and fiddling, I got the new bar in.
Before installing the bar, I checked the fit of the OEM mounts over the larger Eibach bushings and larger Eibach bar. As expected, "re-use the stock mounts" didn't even come close to working. The new bushings have a ridge along both outer edged, which prevents them from sliding into the stock mounts, so, I trimmed off the ridge. See photo. Then the trimmed bushings fit into the mounts, but the flat bottom of the bushings extended below the bottom of the mounts. See photo. That means that tightening down the mounts would really be just squashing the bushings against the subframe, badly binding the bar. So I made spacers from aluminum bar stock. See photo. I believe it was 1/8", but yours may be different. With the spacers in place, the mounts tighened down nicely, and the bar still rotated within the mounts. Kinda ugly, but no one's going to see it...and it's solid.
The bigger bar noticably reduced the roll angle, but I haven't had a chance to push it too hard, to see if it increased understeer. I also installed a Pierce Motorsports Race brace kit, which includes a rear beam axle stiffener, which may help to balance any additional understeer the front sway bar causes. I'll post separately on that.
