Drivetrain Break-in 101
pelotonracer2
NRH
Engine and powertrain Break-in 101
1. Introduction:
Every engine and powertrain is the sum of its' total parts. If those individual parts do not fit together properly (proper
bedding in), or the machined "finish" of those parts after being "run-in" are not optimal, both fuel mileage and
performance will suffer. Even though modern manufacturing processes have improved overall quality drastically over the
last several decades, performing a proper break-in procedure will ensure that your automobile will last longer, provide
better performance and return better efficiency (mpg) over the service life of the vehicle. Not all parts are created
equal, so some luck is also needed to get a good vehicle in the first place. A proper break-in just ensures you get the
most potential out of what you have. That is why even if you take 5-6 of the same car, one or two will always perform
better, get better mileage or last longer than the others. A good "break-in" usually equates to having an above average
car when it comes to performance, efficiency and longevity.
2. The "enemy"
The #1 enemy of an automobile "powertrain" (wear and tear) is heat and cold "extremes". Proper break-in of a modern
gasoline vehicle requires many heating and cool down "cycles" before it will deliever maximum performance and
efficiency. Heat in an engine is a by-product of friction and combustion. Most people, even driving enthusiasts do not
realize that 90% of engine (and powertrain) "wear" happens at engine start up and during the warm up cycle. The colder it
is outside, the more extreme and accelerated this "wear and tear" is. The goal to minimizing this (bad) wear, is to get
your engine fully warmed up in the quickest way possible AND to minimize the number of cold starts during a "cycle". It is
important to note that an engine and other powertrain components are usually made out of different types of metals,
including alloys. All respond to heat and friction differently, and all have shown to have different bedding-in qualities.
For instance, steel and iron is much more durable and more resistant to friction wear than say aluminum or other alloys.
It is even MORE important during engine break-in to minimize cold engine start ups and idling. The absolute worst driving
habit a new car owner can do is start their engine and just let it sit there at idle speed. Idling puts no load on the
engine, provides minimal lubrication on moving parts and takes much longer for the engine to warm up. As metal warms up,
it tends to change shape. In fact, some engine parts are designed to change their overall shape when they get to normal
operating temps (some pistons, with oval sideskirts are a perfect example... as the piston heats up, the sideskirts go
from oval to round). Idling also wastes fuel. The only exception to the "no idle" rule is on days where outside temps are
0 degrees or less. Then it is actually beneficial to start the engine and let it idle for 10 seconds. However, the best
driving procedure for extremely cold days (especially during the break-in) is not to drive the car at all.
The #2 enemy of your engine/powertrain is short trips of 10 miles or less. This is especially true on... you guessed it,
"cold days". If you have a second car (that is preferably well broken-in) it would be highly beneficial to take that
vehicle instead of your new car if you need to just drive down the street and back. Just because your coolant gauge reads
that the car has warmed up to normal operating temps after 2 miles or so, this does not mean all your moving parts are at
optimal operating temps. If you drive your car for 5 minutes and then shut it off, then do the same procedure a few times,
your engine and other vital parts never properly warm up and it's like adding 200 miles of bad wear to your car, even
though you may have only driven 10 miles total during your 5 stops.The #3 enemy of your new vehicle is lugging the motor. The #4 enemy of your engine/powertrain is improper driving techniques.
Recommended cold vehicle start up procedures:
a). Open the door of your car and get in. (duh!)
b). Put your seat belt on and make any adjustments in driving postion, mirrors or plug in your iPod BEFORE starting your
vehicle.
c). Start your engine and slowly drive away imediately. Pay special attention to rpm. Keep revs low, but DO NOT lug the
engine. If you can, during as much of the break-in as possible, leave the air conditioning turned OFF.
d.) Try to keep sustained rpm under 2750 rpm until engine is completely warm. For the first 250-300 miles of your break-in, never exceed 3000 rpm (cruising engine speed). I'm not saying don't use brief accelerations above this limit, just don't drive sustained engine speeds higher than this.
e.) Vary your engine speed AND road speeds. This creates different engine loads, different pressures and different friction values on the sum of your parts as they try to find a way to fit together and find conformity. It also changes the metal shearing process and provides more
even wear-in.
As I stated earlier, 90% of bad engine wear occurs at engine start up. But did you know that about 70% of your break-in
occurs in the first 100 miles? Look at it this way, if you will: The break-in of your new vehicle is nothing more than
removing enough material so that all the parts fit together (parts conformity) so that once the break-in is completed, you
have proper tolerances, fit and finish for optimal performance, efficiency and longevity.
3. The wear time line:
Since 70% or more of your new car break-in is achieved in the first 100 miles, logic dictates that this would be best
achieved in 2-3 driving events v.s. 10-12 driving events. That is because beneficial wearing-in happens while the engine
is running and completely warmed up, versus an engine that goes through the warm-up/cool down cycle a few times in the
same period of time. As an engine (and other drivetrain components) wear-in, the amount of material removed via friction
declines dramatically. The actual SIZE of those metal particles also reduce in physical size also, the more miles you put
on those components. So with that said (and this will sound CRAZY to most people), the best time to change your oil is
between 80-100 miles. I will repeat that, just in case you think you mis-read it. Change your oil after the first 80-100
miles! Why you ask? Well, firstly, your oil filter can only catch so many metal particles and your oil can only suspend so
many particles. Accelerated engine wear during break-in means more miniscule metal particles floating around your engine
just waiting to be squashed or redeposited on other moving parts. This is probably one of the BEST break-in tips I can
give. Change your oil and get the metal particles (the result of your engine parts rubbing against each other) out of your new engine! Having metal particles redistributed onto moving parts can often cause tolerance issues and lends to accelerated wear, increases friction and reduces efficiency. I HIGHLY recommend 4-6 ounces of Marvel Mystery Oil in your FIRST tank of gas ONLY. This aids in top cylinder lubrication and seating your rings. It also protects your cyclinder bore. I would recommend using the same oil brand, type and viscosity as what originally came with your car. Some people will argue (incorrectly) that manufacturers use a special break-in oil or add friction modifiers to their new engines. They used to do this practice many decades ago, but not today. DO NOT use synthetic oil at this time UNLESS your car came with sythetic or synthetic blend to start with. Even though 80-90% of your ring seating is achieved after only 30 minutes of continual driving, sythetic oils (or anything that reduces friction for that matter) will impede ring wear and cylinder bore wear during that last 10-20% of your seat process. Cylinder bores usually have a cross hatch machining process (or grooves) that aids in piston ring seating and oil retention. It is that last 10% of the machining process (of your rings
being pushed out onto the bore from compression) that gives you even better power, better efficiency and MUCH better
longevity. It's best to wait until you have around 7000-8000 miles on an engine before using a full synthetic. After the
first oil change at 100 miles has been completed, you can try some of the new driving techniques stated below.
After another 500-600 miles, you can... or should I say SHOULD change the oil again. Oil analysis shows that typical
engine machining (running in) has diminished noticeably and that the size of metal particles in the oil have also reduced
in size. You still want to get rid of those particles, because as they get smaller, more of them escape the oil filter
"catch" and tend to redeposit on moving parts. They are still a bit too big to stay completely suspended in the engine oil
for longer periods of time. If you decide to skip the 500-600 mile oil change, it is imparitive that you do your second
oil change no later than at the 1000 mile mark. Then your next oil change should be at 3000 miles, and then every 3000-
5000 miles (or whatever your owners manual recommends).
4. Driving Techniques:
The owners manual is very vague concerning driving techniques and habits during the break-in period. The break-in period
driving techniques I will recommend will be broken down into 4 different stages. Each stage is used during a certain part
of the break-in distiguish by a mileage "scale".
Stage 1: Initial break-in period (0-100 miles)
This is probably the most important time for proper break-in procedures to be used because 80-90% of your break-in is
completed during this time.
Warm the car up fully. Vary engine speed (rpm) AND road speeds. Never exceed 3200 rpm at this stage (Fiesta ST specific). It is best to shift at or below 2500 rpm when the engine is cold, but avoid lugging the engine (using a gear that allows too low engine revolutions). Vary your driving. Do not do all of your driving on the highway or on city streets, mix it up every 15-20 minutes for the first 100 miles IF it is practical. Try to avoid high traffic areas, especially stop and go traffic conditions which is hard on new brakes, clutch linings and transmissions. To do a proper break-in, it is important to drive the car smoothly in each gear, being mostly gentle with throttle (this keeps drivetrain "lash" to a minimum). Vary the rpms in each gear. To help break-in your transmission, this means finding a place where you can drive in 1st and 2nd gear for a few minutes at a time. Remember, drive at different road speeds AND different engine speeds. Keep revs above 1800 rpm and below 3000 rpm.
For instance, once the car is fully warmed up start out in 2nd gear at about 2000 rpm. Hold that engine speed and road
speed for 15-20 seconds, then gently accelerate to 2250 rpm. Hold that engine and road speed for 15-20 seconds, then
gently accelerate to 2500 rpm. Hold for 10 seconds. Then.. gently lift the throttle and wait for rpm to drop to 1800 rpm
(coasting helps raise oil pressure and improves top cylinder lubrication), hold 1800 rpm for 15-20 seconds, then repeat
for 2000 rpm, 2250 rpm and then 10 seconds @ 2500 rpm. Then repeat the driving technique @ 1900 rpm, 2100 rpm, 2300 rpm
and 2500 rpm. Do this in each gear. Make sure road speeds are high enough that you are not lugging the engine. I would also recommend very brief full throttle accelerations in in a higher gear (preferably 4th or 5th gears, starting at around 2000 rpm. Gently ease into the throttle until you are at WOT count to 4 and then gently ease off the throttle, letting the engine coat back down to your original 2000 rpm starting point. This helps to seat the rings and provides additional upper cylinder lubrication where it is desperately needed at this point in the break-in.
Stage 2: Secondary break-in period (100-500 miles)
Warm up the car fully. Continue to vary engine speed AND road speeds as in Stage 1. Never exceed 3200 rpm (sustained engine speed) at this stage. It is still best to shift at or below 2500 rpm when the engine is COLD, and avoid lugging the engine (using a gear that allows too low engine revolutions causing the engine to kick or buck). Be sure to vary your driving habitat. Do not do all of your driving on the highway or on city streets, mix it up every 30-45 minutes. Still try to avoid traffic areas, especially stop and go traffic conditions which is hard on new brakes, clutch linings and transmissions/differentials. To do a proper break-in, it is still important to drive the car smoothly in each gear, being mostly gentle with throttle (this keeps drivetrain lashing to a minimum) but using brief (no more than 3-4 seconds) 50%-75% throttle position. WOT
(wide open throttle is 100% open). Continue to vary the rpms in each gear. To help break-in your transmission, this means
speeds AND different engine speeds, even in the lower gears. Keep revs above 1800 rpm and below 3500 rpm.
speed for 30 seconds, then gently accelerate to 2250 rpm. Hold that engine and road speed for 30 seconds, then gently
accelerate to 2500 rpm. Hold for 30 seconds. Then.. gently lift the throttle and wait for rpm to drop to 1800 rpm, hold
1800 rpm for 15-20 seconds, then repeat for 2000 rpm, 2250 rpm and then 10 seconds @ 2500 rpm. Then repeat the driving
technique @ 1900 rpm, 2100 rpm, 2300 rpm and 2500 rpm. Do this in each gear. Make sure road speeds are high enough that
you are not lugging the engine and creating too much load. You can now hold engine rpm and road speeds for longer periods of time. Once or twice per session after following the above procedures, set road speed at 40-45 mph and use 4th gear. Gently ease into the throttle until you are at 100% WOT. Hold for 6-7 seconds, then GENTLY ease off the throttle until your foot is no longer pressing on the pedal and let the engine coast back down to 1800 rpm. Do NOT exceed amount of time @ WOT and DO NOT use a gear bigger or smaller than 4th
gear at this time.
Stage 3: Pre final touch break-in period (500-1000 miles)
Continue to follow stage 2 recommendations. You can now hold road speeds and engine speeds up to 1-2 minutes at a time.
You can now also "safely" be more liberal or aggressive with throttle input and hold the high gear WOT technique to up to
10-12 seconds AND you can repeat this technique up to 8-10 times back to back (acceleration and coast down). Remember to still gently ease into the throttle and let off the pedal gently for coast down which aids in lubricating top area of cylinder. You can also be a bit more aggressive in 2nd and 3rd gears as well but you will STILL want to avoid WOT acceleration in 1st gear!!!
Stage 4: Going the extra mile(s) (1000-1500 miles)
You can pretty much drive the car as you want, but I still recommend following stage 2-3 driving techniques modestly, but
now you can hold speeds up to 5 minutes at each road speed/engine speed (except in the lower gears). The longer you extend
the break-in period (and not start ragging on your car), the more efficient and the longer it will last over the lefetime
of the vehicle. I recommend at least 1500 miles before taking your car to the track OR hooking it up to a chassis dyno. I'll wait until my Fiesta ST has 2500 miles and then I will get some baseline numbers from a chassis dyno. Your engine will most likely not make full power until you hit around 5000 miles anyways. Sometime between 1000-1500 miles is also a great time to change out your oil and transmission fluids. Keep in mind, there are moving parts in the transmission that also mesh together. Changing transmission fluid at this time gets rid of metal particles from the shearing process of your break-in and keeps them from being redeposited onto moving parts (which makes them less efficient, causing more power robbing friction, and less fuel economy). Remember, you are not just breaking in your powertrain. There are
other load bearing parts on a car that need to be properly broken in. This includes your brake pads, wheel bearings,
suspension parts, oil pump, water pump.. even your air conditioning.
So in the end, is it really worth all this extra effort during the break-in? I don't know. You be the judge. It really
boils down to what you intend to do with the car and how long you plan to keep it. However, I can tell you that in my 20+
years of mechanical engineering experience (I built and and tore down literally HUNDREDS of engines during testing and
design), and after building blue-printed parts bin, hand built engines for racing... after buying 47 new cars since 1986
and applying these methods, I'd have to say yes. My vehicles usually made more power at the wheels (stock or modified) on
the dyno than other like models with the same or no mods, have been quicker at the track and have higher trap speeds than
other same make and models, not to mention being able to achieve significantly higher than EPA mpg averages (when trying)
than the manufacturer states. Not to mention, out of 47 cars, and well over 1,000,000 miles driven, I've only had ONE mechanical problem (and that was due to the design and manufacturing) not the way the vehicle was being driven or maintained. I know this because this particular engine used oil since it was new, which only got worse over time until a bearing seized and destroyed the motor @ 58,000 miles. One brand new short block and 3000 miles later, the new one was doing the same thing (using way more oil than it should have been). Burning oil usually (but not always) is the result of a bad bore, piston ring or irregular piston/piston skirt wear. This was a '05 G35 3.5L engine (the same one used in the Nissan 350Z). No excuse for an engine with over 3000 miles to be burning oil especially if it was broken-in right. Come to find out later, based on forum exchanges with other owners, this was a pretty common issue. Not sure about the new(er) 3.7L G motor, but the 3.5L definately had lubrication issues.
Anyways, the above statements are just my personal experiences and opinion. I tried to make this information as simple to undstand as possible so that even a small child could comprehend the information. lol. I also apologize if this comes out not looking right. I wrote in on notepad in about an hour. [8]
Toronto
Very informative! I agree with all u said...as I have done the same procedure with the new cars I bought. Maybe not exactly gear to gear time holding and coast, but fairly similar.
But, I also tested another theory with one vehicle I bought...which was after 750-1000km grandma driving, I started to drive it like I stole it!! LOL...
And considering the vehicle we are talking about here...break in procedure will be very testing to patience to say the least, but I plan on keeping this little pocket rocket. Following the procedure you listed above as close as possible, will make the car last longer, I agree...(the two early oil changes a must!!)
Cheers to all, and happy turbo-ing
Perry
Leawood
Wow. Very informative, and lots of detail to absorb. Thanks.
Question, if I may: Believing that engine break-in is important--though until now I didn't know just how important--my routine with a new vehicle has generally been something like this:
1. Limit number of cold starts. Avoid very short trips. My goal was to especially focus on this for the first 250-500 miles.
2. Get in, start, drive--modestly, meaning without high revs/high torque, but with variation in same. Avoid lots of stop-and-go. Do this for first 1000 miles as much as possible. Also avoid long stretches of same-speed (e.g., highway) driving.
3. Change oil at about 1500 miles.
So, finally, my question--I think I was pointed more or less in the same direction you outline, pelotonracer2, but not nearly so thoroughly or completely thought-out; but am I correct in my overall inclination? I ask primarily as a "do I have the right frame of mind?" sort of thing, or am I missing a really big item somewhere?
I think perhaps the most important bit I learned was the need for a much earlier oil change. While I intuitively grasped the need for an earlier-than-scheduled change, I hadn't thought it through to the point of realizing that a much earlier oil swap was a very good plan.
Another question, too, if I may, regarding synthetic v. "natural" (recognizing that no oil in a can on the shelf is anything like the stuff that comes out of the ground): Why the preference to avoid synthetics early on? I thought, perhaps wrongly, that good synthetic oils were made to match the necessary lubrication specs, while at the same time often having greater "durability"--that is, reduced break-down compared to non-syn. Am I missing something? Seems to me it shouldn't be a disadvantage to use a synthetic, but I'm willing to learn from your much greater experience and expertise.
pelotonracer2
pelotonracer2
NRH
1. Break-in is only important if you care about extracting every ounce of power potential AND if you plan on keeping your car for a long time. Fuel economy is also likely to be 5-10% better over the life of the vehicle. That saves you money. [biggrin] If you only plan on keeping the car for a couple years, then the break-in trouble might not matter. That doesn't mean you should rag on your new car immediately (I've seen a lot of oil usage issues because of this over the years, including other more devastating results).
2. Contrary to popular belief, oil filters can only trap so many particles. The debris that gets by during the break-in is metal particulate. So you have metal, rubbing against metal, trying to find a happy medium so that all the parts conform and fit together. Then you have metal floating around in the oil that gets redeposited on those same metal parts that are trying to find that happy place. This can cause uneven wear, accelerated wear reduced optimal efficiency, increase friction and reduce power. If you care about extracting all the horsepower/torque could potentially make, care about optimal fuel economy and want years and years of problem free motoring, it just makes more sense to change the oil often during the break in. Look at it as a precautionary insurance policy. [:)]
3. Today, most synthetics are not really "synthetic" as the word used to mean. Due to changes in Federal guidelines, "synthetic" can now mean "ultra processed mineral oil" and not 100% man made. They are still very good oil but they are no longer "non mineral" base stock. They just process mineral oil until it meets the synthetic "standard" AND add better or increased additive package. There are a few exceptions (Like Redline and Amsoil) for instance, but most of the mainstream oil companies are now refining mineral oil to meet the Federal guidelines (or definition) of "synthetic". It's cheaper to refine mineral oil than it is to produce 100% non mineral oil. It's all about profit margins. [paranoid] During the break-in, accelerated wear is actually beneficial as long as it is "beneficial" wear. Confused yet? The higher or greater the lubricity of the oil, the less "beneficial" wear will occur (or it just takes a lot longer to occur). Some engines come with synthetic oil from the factory. I usually recommend draining that oil immediately and going with a high quality regular oil or a synthetic blend for the first 3-4 oil changes, then switching back. You won't need to worry about thermal or chemical break-down during the break-in because you won't be wringing it out and putting stress on the anti-shearing property of the oil (well hopefully not... lol). There are definite advantages to running a quality synthetic oil. Every brand is better than the lesser refined mineral oils in most if not all ways.
Perry
Leawood
I'm learning a lot here--thx much. Since I hope to keep my new baby as long as possible, I'm gonna follow your recs from here forward--which means I need to change oil already! Not as worried about wringing every bit of potential power as avoiding mechanical issues and longevity. Thx for the grad-level seminar!
pelotonracer2
pelotonracer2
NRH
No problem, enjoy your new toy! I know am. [biggrin]
rooSTer
Miami
Just spent the last 30 minutes reading this haha...thanks for the share.
HaveBlue83
Williamsport
my car had 101mi on it when i got it......lol. i just ease into it......drive it easy, then after a few hundred, drive it harder......then harder...then i beat it. im at 700mi now. I usually wait until 1K mi to really run a car but this damn thing is a woooooot! I DO let it warm up and i DO cool it down after drives.
dyn085
Vancouver
Break-in is always an interesting topic. Everybody has their preferences, but I prefer to do a hard break-in of three to five redline pulls with an emergency stop down to 10-15 mph with five minutes of easy driving between pulls. Drive home normally, change the oil, live life. It helps to seat the rings and brake pads and everything else can wear-in normally.
iso100
That's how I broke in the total seal gapless rings on our autocross car back in the day.
CanadianGuy
Southern Ontario
Great post and I too share most of those points when breaking in a new car. My total of vehicles is only about 12 band my total km is a little under 2 million km, meaning my average km driven per vehicle is huge. Only ever had normal wear and tear on parts like brakes, etc... Heck my 2005 Aveo @350,000km is still on the original clutch (no slips at all).
All that said I want to add a little point to the first 100 miles above. Which is don't forget reverse. Use it in a parking lot, not at high speed just normal. Even though the reverse is not used allot, it still requires some metal to metal conforming. using it early will allow the metal shavings to be extracted and flushed with the rest of the transmission oil instead of appearing later. Please make sure to be at a complete stop before thinking of changing into the reverse gear for this period. I would even suggest double clutch it to be double sure.
With these and a good maintenance plan your vehicle can last a very long time/distance.
dyn085
Vancouver
Not to mention, out of 47 cars, and well over 1,000,000 miles driven...
Mathematically speaking, this is only an average of 21,277 miles-definitely not a large enough number of accumulated miles on an engine to determine engine longevity.
My total of vehicles is only about 12 band my total km is a little under 2 million km...
Converted to miles (for comparison that us Americans can grasp, sorry) that should equate to roughly 100,000 miles or so, maybe a few thousand miles more. No offense, but I don't see 100,000 miles as being a very good indicator of overall engine longevity either-definitely not in regards to break-in. The only vehicle that my dad or I have ever owned that didn't make that mileage mark (out of vehicles that weren't traded sooner just because) was a lemon Dodge that he owned.
This would be a much better example of engine longevity, though it brings your above average down to around 90,000 miles-not even reaching six-figures.
I know it's weird to mention my dad, but he and I have owned many vehicles, and quite a few of them had achieved 100k miles and were still strong. A lot of our vehicles were traded/sold sooner, but literally only the one Dodge was because of mechanical issues. That gives us a failure rate of less than 1% if we counted all of our vehicles, but still less than 5% of all vehicles that achieved 100k+ miles. Realistically, even less of our 100k-mile vehicles were purchased brand-new by either of us so we wouldn't be able to vouch for break-in anyways.
What I would be curious to know is what kind of break-in was done by all of the users claiming oil consumption or of those that found oil in their intercooler/charge pipes when doing upgrades...I think that would tell us a lot.
frankiefiesta
forked river
I agree. Hard break in always
Santa Rosa
Bout 12 years ago I read an 03 cobra break in. I can not find it now but it went something like this. His stock dyno on a 390hp car was 382rwhp.
First 500 miles below 3k rpms.
800 miles below 3.5k
1k miles below 4k
1.2k miles below 4.5k
1.5k miles below 5k
1.7k miles below 6k
2k miles redline it first three gears.
Also vary speed and rpms greatly first 2k miles and let the motor brake itself. I usually find small hills and have rpms act as the brake going down with no pedals.
pelotonracer2
pelotonracer2
NRH
Thread Starter #18
http://www.mototuneusa.com/break_in_secrets.htm
a few years ago one of my friend made me read this, beeing my self a mechanic i found this article beeing very informative.. [dictate]
I would never break a motor in that way but to each their own. We used to run our race motors similary, but then again we were rebuilding them every 10-20 hours of hard use.
pelotonracer2
pelotonracer2
NRH
Thread Starter #19
Engine longevity is only a small part of the equation. You have to take in account all moving parts. This includes transmission clutches/gears, differentials, axles, wheel bearings, even brake pads and rotors. Most of the vehicles I owned I had concurrently (3 or 4 at a time), some of which were rode hard and put up wet so to speak. Some of them were driven by family members and even friends. Many of them I turned around and sold to friends and family and a majority of them are still running strong with well over 200,000 miles on the odometer.
But as mentioned before there are a few exceptions. None of the VQ35DE (normal AND high rev engines) in Nissan/Infiniti cars I owned are still running. My 2005 Infiniti G35 MN6 sedan started using copious amounts of oil at around 30,000 miles (over 1 quart between oil changes). This consumption increased to 2 quarts. I made the service dept aware of it and had them note it. They also performed an oil consumption test. As long as I added oil (often) it ran fine. However, at 58,000 miles it spun a bearing due to lack of lubrication. Dealer saw that there was plenty of oil in the engine/pan and had it analyzed. It was good. All the reciprocating parts looked good as well, except for damage that occurred when everything let loose. But Infiniti would not repair the motor under warranty because I changed the oil twice myself and couldn't find the reciepts. The oil changes I did my self were at 10,000 miles and 23,000 miles. The oil had been changed every 3,000 to 4,000 miles with Royal Purple synthetic. So I shell out $10,000 for a new short block despite the oil being good and the dealer having noted high oil use. I break it in hard like I just don't care (because I really didn't give a sh*t at that point and had already planned to sell it in the near future). 9,000 miles and 4 oil changes later, it was again using 1 quart or more between oil changes. I used regular dino oil in it the first 5,000 miles and switched over to Mobil 1 synthetic, so I don't think this was caused by the oil. At that point I sold the car to a guy in Austin and he's had nothing but problems with it over the last 3-4 years. Come to find out the 2nd motor took a crap too. However not a single issue with any other parts of the drivetrain, just a ton of oil usage. Despite the journalistic ranting and raving over the VQ engines over the years, I find them to be defective after owning three different cars with them, all having abnormally high oil consumption.
I have only ever had three warranty claims for mechanical issues since buying "new" cars. Four if you add the Infiniti (since 1986). A catalytic converter issue on an '86 Mustang GT, intake manifold gasket on a '97 Dodge Viper GTS (which was more of a recall than a single car issue) and a bad turbo on a '93 Mazda RX-7 after just 2,000 miles. Otherwise, when I buy a car it pretty much never goes back to the dealer.. ever.
With that said, my break-in experience has very little to do with the cars I've personally owned. I was just using that as an example. My experience is with long term chassis and engine dyno torture testing, tear downs, rebuilds and lots of documentation which simply cannot be duplicated unless you work in that field. This type of testing includes thousands of cold start ups, warmups, range variance of load, accelerations and low/high speed (replication of normal engine operation while driving). I was tasked with improving design and implementation, including using parts made from different materials and (stress) testing those parts for durability and performance. Many of those tests were to purposely find limitations of the design to save money for the corporate "bean counters". When you have literally hundreds of examples running nonstop for months at a time (and then can tear down and take a look inside) you literally get to see advanced wear in a matter of weeks (or months) verses years or decades. I can assure you, nothing is built to last forever, PURPOSELY. lol. If that was the case once you sold a car to someone they wouldn't need a new one. They (car manufacturers) want you to purchase something new every 4-5 years.
dyn085
Vancouver
Generally speaking, pretty much everyone that has had oil in their intakes/charge pipes were claimed to have been broken-in with this long and slow break-in process whereas both of my ST's and many of my friends' ST's were broken-in hard and have dry intakes/charge pipes. That alone has told me plenty. There's always more to the story than just that, but it has definitely been a common theme.
As an aside, changing synthetic oil every 3-4k miles is a huge waste of money and time. But that's a whole other never-ending discussion that doesn't necessitate so many words either.
