We will see, for now we want to concentrate on the GT1.
The GT3 very specialise and therefore it will be done on a custom build basis.
Because if we are going to custom build something, we are going to make sure it is going to be tailor made to fit.
As far as price goes, we will come in under all the big names for sure.
Another interesting thing I found earlier this month at the Autosport show.
One of the rather unique feature of the MeisterR GT1 dampers is that we use a double 44mm piston inside.
This is different from other dampers as the GT1 actually use 2 full size piston with 2 wear tape.
This spread the load and therefore increase side load capacity without going into an inverted design.
There aren't much literature on the function of their design, and it is probably different from the GT1.
But just thought it is interesting because this is actually the closest I have seen in terms of what the GT1 internals looks like.
So yes... the suspension certainly work and work very well; with result to back it up.
Jerrick
