I installed my new DiodeDynamics LED projector Fog Lights today.
These units are very high quality and ModBargains have them for $155 with free shipping!
Although ModBargains can also install thsee for you some people may not be close enough or may also not have an installer available.
Here is as step-by-step so that you can do it yourself.
I choose to install Lamin-X lens protection in yellow.
This should be installed before you install the lights.
Next you should install the supplied connector shell.
It is easer to install this before you install the light however it can be done after.
To make sure the connector shell is installed correctley you should remove the current light assembly.
It is easier if you lift the car then remove the lower screw and scrivit from the inner fender.
Next move the inner fender to gain access to the fog light.
There are two screws, one at top on one, side and one at bottom on the other.
To make sure you get the wiring correct, insert the connector shell into the exisiting harness connector.
Next orentate the BLACK wire of the new light to plug into the connector shell and align with the BLACK wire of harness connector.
Insert the RED wire into the connector shell in the other hole and then install the new fog light.
Replace the hardwere in the inner fender then do the other side the same way.
This was very easy and only took about 30 minuites.
Dave
Dave
