Data logging are these readings okay ?
Ryry01
England
Current mods.
Mp215 from factory.
Mountune air box gold wrapped.
Mountune air box cold feed re routed to under the car.
Engine undertray.
Fog light air intake ducts to front brakes.
15mm rear wheel spacers.
rear centre axel brace.
Foam panel filter.
GFB DV+
Ngk Iridium plugs.
Symposer delete.
Direnza 3" cat back
Gravity performance cross over pipe gold wrapped.
Silicone intake hose.
R sport stage 2 intercooler.
Oil catch can from valve cover to cross over pipe.
Pumaspeed lightweight water pump pulley and belt.
Mishimoto thermostat + refurbed and painted stat housing.
Large mouth air intake.
Solid intercooler pipes + silicone hoses
Powerflex rear gearbox bush.
Short shifter.
15mm throttle pedal spacer.
Recent maintainence. 71k
Genuine timing belt kit + water pump
New crank seal + bolt
Valve cover gasket.
Cabin filter.
Fuel pump cam bucket.
Iridium spark plugs.
New battery.
50/50 mixed red granville coolant.
5w 30 morris ford spec engine oil. (Changed every 6k)
K&N oil filter.
Air filter clean+lightly oiled.
99 octane fuel always.
Fully undersealed.
Powerflex rear axle bushes.
Gearbox oil (once per year)
Engine sensors cleaned, maf, map ect.
Clutch+brake fluid changed (atb super blue)
Zero fault codes.
Just wondering if anyone on here can check over my data logging and see if everything seems to be good ? Taken via the torque pro app.
Sports mode fully on, foot flat down in 2nd,3rd and 4th up hill.
Just tried uploading my screen recording and it says files too large to process ?
Any help would be appreciated on how to get those 30 second vids uploaded.
Cheers Ryan
