I know the ecu does not care, i just meant for your personal readings for air flow. I think its a cool tool. Like if you ported the head or upgraded the turbo (wink) you'll be able to see a increase in mass air, even if the ecu doesn't use it.
But since you kept it the same, all bets are off
Where did you get the adaptor? Do they have bigger sizes ? I wonder if I could use something off a different ford car (like a mustang) that uses the same style maf... Then the readings would be off, but... The ecu wouldn't care
