Confirm torque settings for all 3 motor mounts?
boonieville
So I am planning on installing all 3 at the same time today / tomorrow.
I found the settings for all 3 here in the forums, but which settings are for which bolts / nuts are unclear for both driver / passenger sides.
So for the RMM I found:
50 ft/lbs for the large bolts on the rubber bushings
18 ft/lbs for the nuts found on the plate
Driver side:
3 nuts: 92 ft/lbs
1 bolt: 66 ft/lbs
??? pictures on the net show 3 bolt holes where it attaches to the tranny, and 2 that connect to the frame ... not so clear here either.
The picture was a after market one though, OEM might be different
Passenger side:
?? 59ft/lbs
?? 43 ft/lbs
There is the one big bolt into the connection between the 2 parts, but there are 2 bolt holes on the engine part, and 3 on the frame part ???
Could someone fill me in on which torque setting is for what on the driver / passenger sides?
I plan on putting grease on the passenger side "connector bolt" as well as on the bolts for the rubber bushing s on the RMM.
I'm also going to put loctite 451 (blue stuff) on all threads.
Thanks
mk_not_a_robot
boonieville
Awesome, thanks dude!
I also caught this post by Koozy: Screenshot from 2019-03-09 22-23-49.png
So only a small mystery remains, for the drivers side mount where it attaches to the frame.
PunkST
Menasha
Question, do they need blue loctite? Im doing my passenger tomorrow. If so ill pick them up.
High Point
Rear:
Motor mount bolts 52 ft/lbs
Black Bracket to transmission 45 ft/lbs
Bracket to exhaust and studs on black bracket 25 ft/lbs
