Coikover install camber alignment help?
Miami
Hey so i just recently installed bc coikovers and it i got some negative camber while doing so ,i took it to get align and they said they cant fix the camber so i figured the only way is through the camber plate up too ,is this correct or they were just lazy?
jeffreylyon
Pittsburgh
You can use some camber bolts. The BC's don't have an adjustable upper bearing plate?
T
Miami
I believe it is at -2.7 degress the car dosent drive straight at the moment the camber is noticebal do i have to adjust this with the camber plates or the akignment shop shoukd have been able to do it ? Or thats why i have the camber plates on the coikovers beacuse if i drop down the strut to adjust the camber then ill misalign it all again which is fine but in turn i wont know if the camber is alright until i align it again
HardBoiledEgg
Fontana
When you adjust camber the toe needs to be reset
Any aligned shop can fix this. But that much camber is not bad
felopr
JD
Here is the Fiesta suspesion specs
take it to an alignment shop
cant do anything about the rear camber but for the front you can use camber bolts to get to spec
T
Miami
Yeah the rear is fine just the front is whats cambered it has camber plates im going to try to give it postive camber ill post a photo so you can see how bad it is
