COBB Tuning - Focus RS Baselined (304whp/340tq) and Stg1 (319whp/364tq)
BoostBumps
Arizona
COBB cracks FoRS ECU and Begins Stage 1 Tuning...
Great info in video and also tips (from Braden Berger) on how to correctly prep and dyno the RS AWD!
Baseline numbers and a Stage1 pull.
"On the dyno with our Ford Focus RS. Baseline numbers and a Stage1 pull."
https://www.facebook.com/cobbtuning/videos/vb.120914804053/10154261777359054/?type=2&theater
DynoJet / 93 Octane / 92F Ambient / 4th gear pulls
Baseline: 304whp / 340tq
Stg1 (preliminary): 319whp / 364tq
"The IC blocking plate (which COBB removes) is designed to prevent excessive cooling for vehicles in "cold" climates. In these environments LSPI can become an issue and the car will limit power to prevent pre-ignition. We recommend removing this cover for anyone living in environments that are regularly above 50F."
"We've run the car several times back-to-back and have had no reduction in power. Each time, the overboost timer was under the limit."
- Braden Berger (COBB Reverse Engineer / Lead Calibrator)
BoostBumps
BoostBumps
Arizona
- Braden Berger (COBB Reverse Engineer / Calibrator)
El Paso
I'm confused. This is the first time I've heard about this sticker/cover on the intercooler to reduce efficiency. It cools the air too much causing condensation? So why do a lot of us run aftermarket intercoolers, that are designed to reduce intake temps as much as possible, not have these condensation problems. I run a COBB IC, the guys with the huge DHM IC's must be making buckets of condensation. What am I missing here?
Boulder Creek
Here is some more info. Another thing to remember is our little ass turbos generate a hell of a lot of heat so it might not be as big of a issue.
http://www.focusrs.org/forum/9-focus-rs-discussions/3097-what-s-front-intercooler.html
As for not making more power if you watch the video they say "We are calling this stage one, but its really in development." It sounds like stage one could be higher once it actually hits the streets.
BoostBumps
BoostBumps
Arizona
How Ford 'Fixed' The Focus RS's Intercooler After Discovering That It Was Too Cool
https://www.carthrottle.com/post/ho...ooler-after-discovering-that-it-was-too-cool/
"During the Ford Focus RS launch in Valencia earlier this week, I asked Ford?s vehicle engineering manager, Tyrone Johnson, about a rather large blanking plate on the RS?s intercooler. As you?ll see in the video, the reason for the plate is to reduce the efficiency of the intercooler because Ford discovered that in particularly humid conditions, the intercooler was working too efficiently, which caused a build up of water vapour. And because water in an engine is bad news, Ford searched through its parts bin and took the same blanking plate that it used for its diesel Transit van intercoolers and placed it over the intercoolers of the Focus RSs. So you could say, then, that the RS is part super hatch, part practical van?"
IC Blanking Plate Removed (below)
BoostBumps
BoostBumps
Arizona
Ford Focus RS Power Gains and Development
06/30/2016 - Kyle @ COBB Tuning
June 30th ? Preliminary Stage 1 Power Gains
"Our engineering team learned a lot with their time on the RS in England. After more time on our dyno here at COBB they were able to come up with a safe and reliable Stage1 calibration that still offers some healthy power gains. The below will be similar to the released Stage 1 Off The Shelf map that will come on the Accessport!"
When our baseline numbers for the Focus RS were first released, there was a lot of talk about them being inflated and even more concern surrounding the fact we dyno?d the vehicle in FWD instead of AWD mode. There?s good reason for that!
The Focus RS does not have a center differential like other AWD vehicles in its class. Instead, there is an electronically controlled clutch pack that sends a variable amount of power to the rear differential. This system is called the Rear Drive Unit or RDU. When the RDU is active (sending power to the rear wheels), it causes the rear wheels to spin faster than the front. Keep in mind that the dyno rollers are linked front and back so they spin at the same rate. With the rollers spinning at a constant rate, and the vehicle trying to spin the front and rear wheels at different rates, things don?t mesh well. When this is the case, the car actually ?thinks? it is losing traction which results in it intentionally limiting power. The best way to dyno the vehicle is in FWD mode with the RDU disconnected. Even if we were able to prevent the car from limiting power in AWD mode, the gains expressed as a percentage will be identical in either FWD or AWD mode. The actual number isn?t too relevant as it will be different with varying dynos and conditions. Check out another post on Interpreting Dyno Results for more details.
The Accessport for the RS platform will be released soon! Stay tuned for more details on the release and information on hard parts and Staged Packages to come!
BoostBumps
BoostBumps
Arizona
Thread Starter #12
COBB Tuning - Ford Focus RS Accessport Available
The highly anticipated Ford Motor Company Focus RS Accessport is now available from COBB Tuning! Head over to the COBB Blog for information on ordering and power gains!
http://www.cobbtuning.com/ford-focus-rs-accessport-available-now/
https://www.youtube.com/watch?v=KWkALgYNkaA
[video=youtube;KWkALgYNkaA]https://www.youtube.com/watch?v=KWkALgYNkaA[/video]
You heard right! As Cody mentioned, support for the Ford Focus RS is now available! This includes the Accessport with Stage 1 maps, COBB High Flow Air Filter, COBB Shift Knob, and COBB Rear Motor Mount.
BoostBumps
BoostBumps
Arizona
Thread Starter #13
COBB Tuning - Ford Focus RS Stage 1 Power Package Released
http://www.cobbtuning.com/products/ford-focus-rs-stage-1-power-package
Description
The Accessport V3 is the world's best selling, most flexible ECU upgrade solution for Ford. Unlock power hidden within the vehicle by replacing conservative factory settings with more aggressive calibrations. Upgrade forever with off-the-shelf (OTS) calibrations for most bolt-on modifications. It's the last engine management solution you'll ever need. COBB High Flow Filters are designed to permit very high flow rates, minimize restriction, maximize filtration and provide a long life filter. Using propriety Woven cotton and metal mesh with a precision molded rubber base, the COBB High Flow Filter ensures that only clean air passes into your engine for maximum efficiency. Why not treat your car to fresh air with a COBB High Flow Filter and let it reward you with increased power, fuel economy and money savings!
