So, let's summarize here: I'm just trying to say if you don't feel like paying for an e30 tune and having to test every fillup, that simply adding one gallon of e85 to the rest 91 will allow you to use the 93 octane tunes out there. Those are often cheap/included with an AP, etc... Also, yes, for an e30 tune you are looking at using 50/50 e85 and 91 IF your e85 only tests out as e54, which I hear happens down there in AZ... So while e30 tunes can give you a full step of power above 93, there is also much more involved in paying extra for an e30 tune and literally having to test it at the pump every time. But by simply adding 1 gallon every time you fillup, will bring you up to 93 octane and be in the e15 range that a regular 93 tune can handle. So it's literally another mid-level option instead of just using 91 tunes, or all the involvement with an e30 tune. If after putting 1 gallon in, use a 93 tune and just watch your OAR and ignition corrections. If you set up a 91 and 93 map on separate slots you change on the fly or even stop and reflash off your AP if they separate files, but still easier than doing full e30
