Right now there isn't a lot of info out on the FiST and the COBB tune other than "oh wow the car is now really fast!", etc etc etc.
I have a good amount of tuning know-how, as do others. Some may be totally new to this. Given the fact that we all now have a device inside the car that can display a hundred different values in groups of 6 in real time, Questions will arise. Here I will post mine, and other may have theirs to add to this. maybe (IF WE CAN) post up logs and whatnot.
My main questions/comments:
-is timing a set number at a set RPM, or is it commanded via other parameters?
-under 2500rpm the car definitely sees great and noticeable gains. above that tho, it feels stock. Right now I am not really seeing much of a reason to use anything but the OEM tune. when I tuned the FoST with an SCT OTS tune from Unleashed I noticed a felt difference everywhere in the powerband, and it was awesome. I loaded the tune and let it be for over a year. on this car I feel like post 2500rpm there was no retuning at all. sad face. is this a "the fmic is holding it back", or something else to understand why the dyno sheets show small gains after the initial hit? I saw iat's go from 87deg to 101 on a pull.
-the interface is leaps and bounds above the SCT platform. thank you for that. the hardware & software work awesome and flashing is fast!
-i'm looking at a log via excel showing all the data. looks like (stock tune Stage 0) shows:
Stock A/F R:
14.0 @ 1800
13's up to 2500
high 12's from 2500-4300
12.5 from 4500-5200
low 12's from 5200-5800
High to mid 11's from 5800-6200 (I lifted after that)
Stock timing was:
10deg lowering down to 1 from 1800-2500
1-15deg slowly increasing to redline from 2500 on up.
Stock A/F R:
14.0 @ 1800
13's up to 2500
12.5 from 4500-5200
Stock timing was:
