Has anyone been able to figure this out? Twice in one month my
clutch pedal has stayed to the floor without fully disengaging. What's weird is that the pedal should come back up because of the spring. My fluid is full and there's nothing leaking at the pedal or the trans.
Seems to be an old thread. First seeing it.
If you're not loosing any hydraulic fluid, may be an issue with the self-adjust clutch. Self-adjusting clutch... wait, what is that?
We have a hydraulic system connecting the clutch pedal to the clutch assembly. In a traditional clutch design, it's the diaphram springs that provide the return pressure for pushing that pedal back up. The spring on the pedal just makes sure it returns to the bumper so you get that "free-play".
(search 'adjust clutch pedal free play engage height') Other than loosing free-play, a weak or non-existent spring on the clutch pedal, should be of no consequence.
But just like our flywheel is far more complex, (and now a potential point of failure,) it turns out that our clutch cover is more complex. Thinking we had a traditional design, I was all ready to point at the clutch hydraulic system; given that this was intermittent. But reading up on this clutch cover spring design, now I'm thinking this part is in play as well; possibly interfering with spring function. See details in the image below, re self-adjusting clutch.
The clutch master cylinder is the cheapest and easiest part to reach. Plus it is capable of leaking internally, as well as externally. The slave can only leak externally. Slave is inside the transmission bell housing; requiring transmission removal. With many car designs, a master cylinder with an external leak, typically puts fluid at the plunger on the firewall. With the slave cylinder being internal on the trans bell housing, unfortunately we can't look at slave cylinder for movement amount and consistency. So there's no easy way to tell if the master has an internal leak.
Traditional Design:
Our Design:
![1597895096933.png](https://www.fiestastforum.com/data/attachments/33/33312-bd115ebc833143988aa0cc3c7f4ba99c.jpg)
