Hello all,
I have an issue with my clutch/clutch pedal that my dealer is having trouble diagnosing. I?ve done a little research and have not seen anyone having the same problem. I figured asking here would be a good next step.
The issue:
Sometimes when I am releasing the clutch pedal, it will only release about an inch, but will fully engage the clutch. I can continue driving & shifting with the reduced pedal travel but obviously when this happens at random it can be surprising and lead to jerky shifts or stalling. It?s as if the clutch is operating normally, but the clutch pedal only moves 25% of its normal range. I can pull the clutch pedal up with my foot and everything seems to go back to normal.This has happened while taking off in first and shifting from 4th to 5th on the highway. The issue has occurred 3 times in the 6,000 miles that I have driven the car.
If anyone could offer any insight into this issue, it would be greatly appreciated.
**Update**
I just got a call from the dealership I'm working with. They were able to replicate the issue and are replacing the clutch pedal assembly. I wasn't able to gather exactly what the issue was, but it seems to be solved for now.
The issue:
**Update**
