Hey guys I have a 2016 Fiesta ST. I recently had my transmission go out. I replaced the transmission and also replaced the clutch slave cylinder and put new fluid in it. After all that was changed we bled the lines and my pedal started to stick I noticed that my slave cylinder was leaking so I redropped the transmission and replace the slave cylinder again now nothing is leaking and we bled the lines again but my clutch pedal is sticking whenever I shift hard at high RPMs for example doing a pull. Any other times it will not stick but whenever my RPMs reach the 6000 and I shift it will stick for maybe one second then release any help will be appreciated thank you
