So recently purchased a fiesta st line black edition 2017 in January 2023
And from day dot had an issue with the clutch
When the vehicle has sat for a period of time when starting the vehicle and putting it into reverse or first the biting point of the clutch is right on the carpet and the car won’t come out of gear so have to turn the car off and start again with this the bite point is just off the carpet and there is slack from the pedal on release, once the car drives the gears and clutch are absolutely fine this seems to be a very intermittent problem and had the vehicle into a main dealer when they said they can’t find a fault and then a couple days later the problem reoccurs any ideas of what this could be there is no leaking in the footwell or the underneath it also seems to occur when using the clutch in traffic ???
