Two other things for you to think about...
#1 if you or anyone else wants one, we can build a X37 in the same time it takes to build a cyborg39.
#2 We use OEM ford/Borg Warner bearings housings. Ever see those Garrett GT35 turbos on eBay that at $350 for a Garrett turbo that normally cost $1500 ? It's all "aftermarket parts".
This is a OEM core bearing housing (SiestaRider's actually ). Oil feed hole.
This is a bearing housing from an X37. Notice... No casting numbers ? That's because it's built from an "aftermarket bearing housing".
