CLOSED: Cyborg TurboCharger * NOT AVAILABLE *
Status
Not open for further replies.
Sourskittle
Sourskittle
Lakeland
Thread Starter #801
Cyborg upgraded stock Turbocharger system
On the first map, I was completely out of fuel.
aFR went into mid 15's.
Added 1.3 gal of gasoline,
But its only going to
Get me so far.
Making boost pretty fast though, think I saw 28psi at 4900rpm :0
Strike that....
Fuel system starts to loose the battle at 5800rpm/26psi
Sourskittle
Sourskittle
Lakeland
Thread Starter #804
Sound advice for anyone with an external gate.
Thanx again Badhelp.
And thanx for helping me with feedback to help get this external gate under control so I can advise others from experience instead of theory :)
For the record... My external doesn't seem too too loud, but on the flipside, I have my 2J intake jetliner intake screaming in my face, my catless 3" turboback yelling and mine doesn't even crack a sound until around 5000-5500rpm give/take.
Siestarider
Stuart
Here I am trying to be stealthy and there you are, 150 miles away, a rolling advert for Fist power. May we both be gone before the Popo ever knows we were there.
jayrod1980
Viva Las Vegas!
So SS, this is always something I'm saving money for... We talked before about me wanting to keep things civilized so to use the Tune+ IWG when I do my cyborg, with catted DP etc. How much HP is left on the table not going external? Keep in mind I'm stuck in the land of 91 octane and I don't plan on doing an ethanol mix every time I fill up or put a meth system on my car. If after all that on EWG you are making 285 whp, is the civil setup only like 240 whp? I wonder then how much is gained over a typical "stage 3" setup if that's the case. I want to make at least 50whp with this setup.
riverbank
I'll let you know once I start my e30 Tuning.
It is not all about making the HP, it is also very much about moving the torque curve up and widening it out which will make the car much faster all around and more fun to drive than the stock turbo can no matter what stage you go with:)
jayrod1980
Viva Las Vegas!
I'm specifically not looking for e30... Just everyday driving. I'm aware of the widening of the curve, it's the reason for the hp increase. I'm just trying to see what people are putting down with a base 91/93 octane and internal wastegate setup. I might have to go external but I don't really want the racket.
Sourskittle
Sourskittle
Lakeland
Thread Starter #811
Honestly, its too early to tell really. I just put 93oct in my car since it can't fuel E30 runs in cooler weather properly. I mean... It can... It just isn't something I want to be running lean AFR's on while trying to dial in a boost curve table. I yanked all the timing and dumped a lot of fuel just so I could get a happy boost curve before adding them back in and it wouldn't fuel the car correctly past 5800rpm.
So today, I filled it up with 93oct and loaded my old 93oct tune. Only got one log in; and just checked it a bit ago... Yep... Throttle shut on me at 3100rpm, and I killed the pull at 4300rpm ( cobb 93oct timing tables with -3.00 degrees trimmed off the top ). So I just fixed the throttle tables ( hopefully I don't have to keep readjusting them ). So I'll give it another shot tomorrow.
Point is... I'm tuning on 93oct pump gas. I can't promise epic results because I'm known for ditching 93oct pretty quickly for E50, but since my car can't fuel it, I may stick with it until I get me aux meth fuel system installed.
Turns out... The external gate with this new vacuum line is doing what I hoped it would. Just crossed my old "best datalog ever" 285whp run against one of my janky new runs from last night and compared them for "spool purposes".
The new setup at 4000rpm was at 26.4psi while the old setup was at 25.3psi. Not a real big difference. But keep in mind, this was a great log vs one from a brand new setup.
But then... I moved up a little.
The new setup made it to 28psi 500rpm faster than the old one. 4500rpm at 28psi vs 5000rpm for 28psi. I want to say I saw a different log yesterday that showed 28psi by 4300-4400rpm I think... Wait.. It was the datazap I posted !! 4413rpm with 28.01psi. So give or take 600rpm faster to 28psi. Also keep in mind, I still have the internal wastegate path in my turbine housing, I THINK ( I don't know, YET ) that some response is hidden in smoothing it out and welding it up like I've been doing for customers as well.
Now onto the thing about the external making noise. #1, even on my 93oct tune that will have lower boost and the gate opening up EARLIER than E30-E40 tunes, the gate should stay 100% silent until 4000rpm at WOT. If your running E85 mixes; than it could be quiet until 5000+rpm when it opens. Even at part throttle past 4000rpm, your gate will prob stay closed. Its only going to make extra noise if you ask it to. #2 I personally don't think its crazy loud. Maybe it is outside the car, IDK. #3 you gotta have some friends or a junkyard or ebay that has stock sport bike mufflers just laying around, they are stainless, and they make sport bikes almost silent, so they would DEFINITELY do the job. I love mine. Even if I got the option to go back to a stock catback and quiet air intake, I'd leave the wastegate dump because unless you MAKE IT LOUD, its silent. And its not like you just fall into 26psi with this turbo ( unlike the stock one ).
I will warn against using an external that is re-routed into the cat back. SRT4 guys have documented that it just about defeats the entire point if you plug it back into the catback. If your going to re-route it back into the catback, lets be clear, your doing it for 1 single reason PEROID. And that is to have 2-ports on your wastegate and to run the vacuum line setup I outlined. I don't think its worth it.
The internal gates do a good job. Nothing wrong with them. Mine has served me pretty well over the last 18months. But other platforms have proven the external gates make more power and sometimes increase response, and its only a matter of time before we know it as common knowledge as well.
Back to power figures... I'm going to keep doing what I've done from the start. What will your car do? I really can't say. I'm not your mechanic, I'm not your tuner, and I'm not the one who makes the choices of "what intake or catted downpipe". 240whp is a realistic number for everyone I think. Pretty sure some guys have made more like me. But if your going to handicap the car from front to back??? Catted downpipe.... 91oct only... Quiet catback... Quiet intake... IDK... You could end up with 200-215whp, which may sound bad compared to a lot of the "generous dynos" cobb may have put out, but real world basically stock cars + intercooler cars on 91oct likely struggle to hit 190whp at 5400rpm. 215whp at 6400rpm could actually be a huge gain at 6,400rpm. But I think if your going to limit the engine in almost every way possible, then.... Not sure a stock turbo upgrade makes sense. A $4500 big turbo can over come some of those things because it makes power without trying to hard, but when your stacking inches to get down a mile road, you can't skip 12 one-inch things and add a single 8-inch thing and expect the total to come out to 20-inches.
If your going to run a cat.... I super highly recommend a dumped external gate. If your going to run a cat and an internal gate, then... Just don't say the cyborg didn't live upto any grand promises. We have seen it. And it didn't work great. The downpipe was custom built to the highest quality, the cat was a "super awesome deluxe pimp juice infussed epic-cat with 17-trillion mega to cells" and it flowed like crap, it was a restriction, and the owner put a lot of nice parts into it just to replace it with a catless DP.
The external completely circumventing the cat and dumping a large amount of the hottest gases directly from the exhaust ports to the atmosphere; I think would make a catted downpipe an option. Other wise, I just can't recommend it :)
But I'll still sell you a cyborg if you want !!!! Lol. My car on 30% throttle to 4100rpm with -3.00 global timing pulled made 200whp at 4100 tonight on 93oct, so... Who knows, lol. I'm ok with being wrong :)
Sourskittle
Sourskittle
Lakeland
Thread Starter #812
Just because I like pumping you guys full of irrelevant info... The fiat Abarth 160hp motor not only has a turbine wheel that is a lot nicer than ours, AND a compressed housing that is bigger and nicer to work with, but it comes with a billet compressor wheel that is a good but larger than ours.
riverbank
May have a better built turbo, but I'll tell you what, it'll never outrun Ugly!! [giggle]
frankiefiesta
forked river
Hmmmm interesting... Cyborg it and put it on the FiST!
TempeST
Honolulu
I agree with the "cyborg it"
The fiat abarth turbo, granted the 1.4l may have something to do with this, but it is quite laggy for a stock platform. mine didn't start spooling till 3000-3300 on a good day. but if its power potential is higher than ours... maybe it could be a good alternative. especially with the billet wheels.
Sourskittle
Sourskittle
Lakeland
Thread Starter #816
The shaft will not fit inside our bearing housing. The comp housing will not fit our backing plate. The turbine will fit our turbine housing, if we spend many hours machining it, lol. I promise, it was looked at long ago. We actually sell upgraded turbos to a vendor for the fiat platform. And use the cyborg wheel in it. And I've been told its made 280whp. But they also machined out the fiat turbine housing which is a "no no" for response. And I think it may have been one of those cobb dyno's, lol. Either way, they were happy with it.
Campbell
I wish you had a way to Cyborg a K04 for a Fiesta ST, It has a larger turbine which I think is the limiting factor and I bet you could find a turbine housing that lines up like the stock turbo. I wish I had my hands on hundreds of turbos like you, I would love to try and make a better mouse trap.
TempeST
Honolulu
The K04 does sound like a great option, I'm sure it can be done. but how much work it takes to get it done may not be worth it. It just seems like a good sized turbo for this platform. Not knocking the Cyborg by any means. but a slightly larger turbo as the K04 would probably be a slightly higher output turbo for us. Maybe SS has looked into that as well. lol
Sourskittle
Sourskittle
Lakeland
Thread Starter #819
Lol. Yea... Its been looked at. The issue is... A K04 turbine wheel is actually BIGER that the turbine housing its self. Another issue is that the more parts and machining we put into something, the more the cost vs benefit is effected. A $2500 setup could be made :)
But... ATP GT2567 is in that room too :)
TempeST
Honolulu
what exactly is the issue with fitting the K04 to our manifold? is there just not enough room or is it the flange that is stopping it? just a quick curious question.
Status
