So I thought there might be some more interesting plot points to share vs plan old peak power numbers...
#1 200whp by 3900rpm
#2 250whp by 4400rpm
#3 280whp or more between 4800rpm and 6300rpm peaking at basically 300whp.
This is was done on my daily driver map, not my race map :0 and it's also a 4th gear pull, not a 3rd gear pull ( 4th gear pulls typically read lower ).
Also.... a little homework/challenge for EVERYONE. Big turbos, stock turbos, hybrids. Everyone.
Set your "smoothing" to "1" and post a V-dyno of that pull where your car makes good power. Let's see how smooth the power really is.... before you comment, just do it
I do realize and believe that it inflates V-dyno numbers to use a lower smoothing number, but that also assumes that your V-dyno on "smoothing 1" isn't smooth...
