CLOSED: Cyborg TurboCharger * NOT AVAILABLE *
Status
Not open for further replies.
DHM1
Royal Oak
Which is why I think 110 is reasonable with 40-50 more whp and an extra 1000rpm of usable power! There's no doubt that DHMs kit is the best for drag racing but the cyborg can pack a punch.
I think our ST280 cars will go 110mph on e30 pretty easy
Russ
Siestarider
Stuart
https://youtu.be/nneznjVugvU
Look at the exhaust I made 363whp on, and the new exhaust I'm going to run on the cyborg.
https://youtu.be/jI8R-ZNRCDc
And here is a shot of the car currently..
https://youtu.be/elRDu_2OLLE
Your new exhaust is beautiful. I will be curious to see if you can attribute any hp gains to it over the stock muffler. I just mounted a Mountune CBE replacing my custom 3" system, for me the swap made no hp difference, just noise. Now that I have tracked the Mountune, its loud enough to shift by note, so its loud enough. And quiet enough on street to be stealthy.
re-rx7
Ardmore
Russ
If they can im all for it. However, I think its a long shot. You are talking about being as fast as 5.0. That's a lot of trap.
Hudson
Looking at power to weight these cars should be as fast as a 5.0 with 280-300whp and they will have a better powerband
re-rx7
Ardmore
Better powerband? lol ISh ran a stock 5.0 with his x37. Car was making 280ish. He got drug dirty. Vid is on youtube.
re-rx7
Ardmore
Those are 3.73s gears for you. 3.33s would be a bit closer I believe.
3:31, and on the highway the 3:31 car is faster than the 3:73.
the extra shift in the 1/4 hurts a lil in the 3:73. Notice how the traps are the same on the PP and base?
Sourskittle
Sourskittle
Lakeland
Thread Starter #2,316
New water pump....
Water pump goes here...
Back on that stock Motor mount and filled RMM.
Drove here home, had to gut the timing and WGDC from the tune before I can get some logs :)
re-rx7
Ardmore
Damn timing belt.....SOB. Anyway, about done with the 93 tune. 25psi or so, starting the 1 on 1 E30 with Ryan Sat. Worth the extra to just do it all one night.
Sourskittle
Sourskittle
Lakeland
Thread Starter #2,318
Drove to work on 6psi max, lol. Massive power !!
Status
