Hello Just bought a 2015 Fiesta ST from copart.
Issue im having is The AC and Heater Does Not Work. Nothing blows out of the vents whatsoever.
Have no clue what it could be, checked fuses and swapped around some relays and still nothing.
When you press the buttons for dash, floor or windshield, do they light up at all? What about other electronics in the dash? Sound system, traction control, floor lights, etc.
Based on that, and assuming the fuses are fine, I'm assuming its the blower motor.
I would NOT want to do that job as it seems a huge pain. It's located under the driver's side dash, back by the firewall, around the steering column.... woof.
Yea all buttons light up when pressed, radio works, everything seems in working order.
There is the clicking noise near the driver side and another clicking noise coming from the passenger side
The clicking noises are coming from the blend door motors. It's strange to think that they're both broken at the same time, but these are known to be weak and do break frequently. However, AFIK, these only manipulate the vents and shouldn't have an impact on the actual flow of air.
Do a search for the blend door motors and you'll find plenty of resources on how to find and replace them. It's a pain in the ass, but gets easier the more you do it. I can have either side out and back in within 15 minutes now.
