Hi when i press clutch to change gear theres a knock from behind centre of footwell, again when clutch is released, and also when pressing the accelerator pedal harshly taking up drive. All 3 engine mounts have been replaced, and no noise on full lock turning. Here are 3 vids i took to show noise. The louder 2 are with 1st gear engaged, drivers side only jacked up, and the more quiet one albeit with a knock is in neutral so no connection with gearbox and flywheel. I ran out of time so couldnt check the nearside operation, but the noise does seem to be coming from the gearbox area, although sound does travel....
