Cheapest ABS bleed programmer?
Baldwin Park
Anyone had luck on a cheap programmer that has abs bleed?
How do we change the fluid out around the module without one?
Are our fluid changes only partial because if this?
Read on the forum that some programs would work only on European Fiestas,
Having issuess with spongy brakes after front brake change and brake bleed... also after some panic braking in dirt...
CSM
Cleveland, OH, USA
hmmmm curious to see what people respond with
My method is to do a full bleed, then go out and do a few panic stops on gravel or dirt (like you did), and then rebleed again. Has always worked for me.
B
Baldwin Park
