CG's daily fun ride
CanadianGuy
CanadianGuy
Southern Ontario
Thread Starter #285
June 11th 2017 Hot day meant staying in the shade Tire Lettering
They are not perfect. Will require a few more coats to make it even but I and happy with how they turned out. Used Sharpie oil pen, cleaned the area well with a rubber safe degreaser and alcohol, applied light coats and used a heat gun in between coats.
Calgary
Damn that looks good! Hate to say it but I'm gonna have to steal this idea. The sharpie you used, fine or medium tip? Did you find that the paint bleeds at all?
CanadianGuy
CanadianGuy
Southern Ontario
Thread Starter #287
Medium tip. Fine could be used if you want small lines instead of filling an area. Make sure to prime pen on a peice or cardboard or rag not on the tyre. Also for additional coats treat the pen like a paint brush moving the paint without touching the actual surface. There was not much in terms of bleed so as long as the Peter is raised or lowered it work well.
That looks SHARP!! [thumb]
But my RS-RR's side walls turn brown so quickly (and they've NEVER even had any 'dressing' of ANY sort on them at all since new!), that I must use a brush aggressively on them at washing time, so this lettering would probably get rubbed off. [:(]
CanadianGuy
CanadianGuy
Southern Ontario
Thread Starter #289
Possibly if the brown is from the tyre. If the brown is from the brake dust it should be fine. To remove the mistakes I did I needed to remove rubber. Mine have been cleaned for a few months now and tyre shine applied.
CanadianGuy
CanadianGuy
Southern Ontario
Thread Starter #290
July 1st 2017.
Finally got around to installing some oil monitoring gauges. I had many false starts with this as I wanted the gauges in the small cubby hole. I tried 2" ones but they were too deep. The equus 1 1/2" fit perfectly. I cute the cubby out and installed the bracket from the back with liberal use of JB weld. I replaced the incandescent light with LED back light (much bright and nicer, picture does not do them justice). I fished the hose through the sound symposer tube (pretty easy). The kit have just enough tubing, the water temp sensor was too big for the sandwich plate so I will order their electric version. Don't really need the volt but meh why not. The main goal is to have a true oil temp and pressure monitor, especially in winter. Over all I am happy.
CanadianGuy
CanadianGuy
Southern Ontario
Thread Starter #296
Nice install! looks really good!
I don't understand the cutout; is there a pocket behind the pocket? (I obviously haven't had my dash apart!)
It's actually two pieces they have hot glued (plastic melted) together at rivet points. I undid the rivets and cut the pocket out to fit the 3 hole bracket from the rear. There is not much more space behind but this made for a very clean look once reassembled.
