Okay, so after my long drive today, I figured that I would go ahead and check my catch car to see if there was a difference in the amount of oil collected in the catch can with the breather and valve installed vice just having the catch can. This puts me at around 1500 miles since the install of the breather and valve, last oil change and the emptying of the catch can...to my surprise, the catch can collected nearly twice as much oil as the last time I checked the catch can ( btw, I check and empty the catch can about every 1500 miles also). I usually get about half an ounce every 1500 miles, but this time I got around an ounce. Now, I will say that I used a different oil this time. I usually use AMSOIL 5w-30 signature series, but this time I used Royal Purple 5w-30 because I had the day off and I didn't want to wait for UPS to deliver the AMSOIL. I have my AMSOIL for my next oil change, btw. Sooo, the higher amount of oil caught could be because of the different oil and/ or the fact that it's been much colder outside over the last few weeks. Either way...the breather and valve didn't reduce the amount of oil pulled into the PCV. I still have no residue around the breather as well. Below are two pics of the amount of oil that I have caught in the catch can. One is without the breather with AMSOIL and warmer air and the other is with the breather with Royal Purple in cooler air.
Without breather/ valve with AMSOIL and warmer air outside
With the breather/ valve with Royal Purple and cooler air outside
