About a month and a half ago I installed the X37 turbo, along with the colder spark plugs that Tune+ recommends.  I also started running an E30 tune from Tune+.
I am having real issues with the car not turning over like it should. When its completely cold, it almost always starts up without a problem. However, once the car is warmed up even a little bit, I am having really bad starting problems. The engine will just crank and crank and crank without turning over. Sometimes I have had to try up to 5x, with at least 7 seconds cranking on each try. I've noticed that if I push the ignition and wait for the gauges to activate before starting, this does seem to help a lot, and will turn over after about 3 seconds of cranking, but this does not always work and it still takes quite a while sometimes. I'm worried that this extended cranking could be reducing the life of the motor, plus its embarrassing as hell to be sitting in a parking lot trying to start your car over and over again. Once the car starts, it runs great, and I have had no other issues. I would say the car has trouble turning over probably 50% of the time once its warm.
Any ideas on what this could be, or where I could start troubleshooting? I am afraid the dealer won't want to touch the car if they knew about the modifications.
Thanks,
Thanks,
