Can you mix motul dctf with factory motorcraft dctf
U.S.A.
I recently put in a used trans and had to pull again due to slave cylinder failure. Lost a little fluid when pulling out axel. It has brand new motorcraft dctf from ford but I have some motul dctf laying around. Can I top off with motul or do I need to do full flush and fill?
Capri to ST
CHAPEL HILL, NC, USA
I probably wouldn't do it, but that's more from having a good case of car OCD than any particular knowledge that it wouldn't work. I would check and see that the Motul DCTF meets the Ford spec, if it does you'll probably be fine, if it doesn't, then that's a legitimate reason not to use it.
