Lately, I've been smelling the smell of burnt oil when I drive my FiSt. Didn't think much of it because it doesn't last long but the smell is pretty consistent every time I drive the car now. Depending on how long the drive is, I can smell it a few times throughout the drive (like a drop is hitting something hot every now and then). Car has just over 5,000 miles on it. Mods are listed below.
I decided to check and drain my OCC last night to make sure it wasn't leaking, which it was not. What I did notice while under the car was some oil residue on the cast metal bracket for the passenger side axle, a drop of oil on the bottom of the turbo band clamp and some light oil residue on the back of the block near the exhaust manifold and in that general area. Can't find the source though. I'm trying not to freak out because of the issues I've read about on the earlier MY FiSTs, but mine shouldn't be prone to the earlier issues as it's a 2016 with a late 2015 build date yet, the symptoms are eerily similar to some of the threads I've read on the issue.
I'll try to get some pics this weekend and update the post. Anyone else had similar issues and have the fix be simple like a loose fitting or something?
Mods:
GFB DV
Cobb FMIC
K&N Drop-in
Damond OCC
VelossaTech Snorkel
Stratified Flash Tune
EDIT: A little late, but here are the pics. Appears to have gotten worse as there's now oil on the IC piping too.
Mods:
GFB DV
Cobb FMIC
K&N Drop-in
Damond OCC
VelossaTech Snorkel
