Bulk Lamin-X Fog Cutting size
Sioux Falls, SD, USA
I have some leftover sheets of Lamin-x from past projects. I see that the fogs are 70mm and I can figure it out but has anyone cut their own circles and what size did you use?
I have circle templates to cut good circles just wondering if I should do 69mm or less or if the 70mm is the actual size of the glass or what.
I can get the tissue paper out and make an accurate template but I might be too lazy tonight.
