As title says, brakes currently won't lock up from full pedal force as if the brakes are lacking clamping force. I've recently installed Goodridge SS lines and EBC yellow pads on the front. Used all 500mL of OEM Ford DOT4 brake fluid during bleeding to make sure not a single drop of old fluid was left.
Just took my car to track last Friday and the first thing I noticed was that I couldn't lock up the brakes no matter how hard I tried even with crappy Nexen tires. After the track day, I've tested again on the streets. It's conclusive that the brakes won't lock up. Any suggestions or ideas?
The only thing I can think of is that the Goodridge SS lines is much longer than stock, but fluid should always be pressurized so this shouldn't have any affects right?
