Power Stop Autospecialty. I have heard negative talk. What do you think? Centric has a kit. How about that one? I need a lot of brake. Lots of hilly gravelly roads around here. In town passengers can walk if they don’t like bite. I am leaning toward Motorcraft pads. If I could save on rotors that would be good. If you like initial bite stick to motorcraft brf 1444 and 1494. Nothing will have the same initial bite. Hawk 5.0 are great and have excellent stopping power, lower dust and 7/10 the initial bite of the motorcrafts. Stay away from any Centric, powerstop, R1Concepts or any ceramic pad. You will
Yo I responded to you in my other brake thread. I ran PowerStop rotors front and back for almost 40,000 miles on both motorcraft and hawk 5.0 front pads. They worked great. Motorcraft pads have the best initial bite and excellent power. Hawk 5.0 pads have 7/10 the initial bite, more modulation and less dust. Any Centric, powerstop, R1Concepts or any ceramic pad won't be up to your standards and will have horrible initial bite and less stopping power. The only other pad I'd recommend is ebc yellow but they are pricey and dust as much as oem.
Get cheap rotors and good pads.
Why do you want vented rotors only in back? Your fronts do most of the braking and your rears shouldn't overheat. Slots will help with water, dirt and debris but will be more effective up front. If you're wearing out rear rotors fast you need to always drive in Sport Mode. Especially in gravel where I'm sure you want rotation, you don't want the computer braking your rear tires trying to keep you straight.
