When picking tire sizes you need to look at actual specs as the numbers on nearly all tires are rather arbitrary and the application you need them for.
In general the best performance for handling will be with a 205 or 215 width and a diameter not to much taller than stock.
Section width and tread width vary greatly from tire to tire which is very important to consider as a mild stretch has been proven to be faster and is used a great deal in setting up cars for many types of racing, track events, etc....the slight loss of grip, if any, is exceeded by much better feedback and control which is quite critical driving on the edge of adhesion which is the best part of going fast
I see with your mod list and picture you are setting up for some track use, great!!!!
BFG has the Rival S in 215/45/16, 23.6" diameter, 8.4 section and 7.3 tread width, 20 lbs so pretty low in weight but seems to be developed for autocross more than road course use.
Bridgestone has the RE-71R in 205/45/16, 23.2" diameter, 8.1 section, 7.1 tread width, 19lbs and from what I have been hearing might be a better compound for the track.
Dunlop ZII Star Spec, 205/50/16, 24.1" diameter, 8.4 section, 7.5 tread width, 21lbs a bit on the tall side so clearance starts playing a part.
225/45/16, 23.9 diameter, 8.9 section, 8.5 tread width, 23lbs, one of few 225's but really should be on a 9" wide rim
Hankook RS-3, 205,45.16, 23.2" diameter, 8.1 section, 7.5 tread, 20lbs,
I would have to look at other sites for more alternatives, there are a couple that might work out for your needs if you want Extreme summer tires.
If you are looking into a bit less summer only tire or high performance all seasons I will gladly look up what would be good choices to help you out
I am retired and also suffering from old injuries right now so more computer time and I love helping others
I plan to be down in Perris CA for couple of days and if open heading to Goodwin Racing in SD to check out things if I can get mobile enough to go by the end of the year if you or anybody wants to see about hooking up
Back to the wheels!
I would have to have them in 4x100 if available and in black or graphite, etc....
I would like to run them with the BFG Comp-2 A/S in 205/45/16 but the specs make it almost to narrow for an 8" wide wheel....so would likely go with the 205/50/16 Mich PS-3 A/S which is considerably wider. I have ten wheels with 225 wide tires on them, track and summer, 9" wide.
Back to the wheels!
