Having an issue where the car won't boost past 5psi. Currently the car has. After market intercool and mishimoto intake. I'm on a custom tune from Adam@ tuneplus. The issue always comes up after about of mile of driving from Turing on the car. At first I thought my wastegate was going out but I notice that if I would switch off the car and turn it back on all the sudden I have boost again. So I then thought maybe the wastegate solenoid. So I purchased a brand new one from Ford. The issue continued. I've been monitoring the WGDC actual on the accessport port and notice that one the car is just turned on the wastegate sits at about 8% at this point in can go WOT and will hit peak boost ~25psi but after about a few min if the car being on all the sudden the WGDC goes to 0% and stays there untill I turn the car back off and on. I've read somewhere that if the WGDC is a 0 it means that there is no input going to the solenoid. So I'm lost now did the brand new solenoid that I bought come defective or is there other sensors that control the boost? Is my wastegate getting stuck if so why does shutting the car off and back on fix the problem momentarily? Anyone here ever run into a similar issue?
Sent from my IN2017 using Tapatalk
