Quick question regarding boost and throttle position.
Obviously, throttle position and RPM play a big factor when it comes to an engine and turbocharger producing boost pressure.
When in first gear, you can easily bring this specific engine up to redline using very little throttle pressure, pretty much utilizing the engine as naturally aspirated, no boost pressure required to travel the entire RPM range.
My question is, when driving in normal everyday situations, how much throttle input is required for the engine to create/utilize boost? More specifically, when do you see your FiST making boost? 1/8 throttle? 1/4 throttle? 1/2 throttle? What psi do most of you see in normal city driving?
Also, what RPM do most of you see boost coming in at? With a small turbo, boost is more easily made at lower RPM due to a small turbine but what I’ve heard from others, the fun seems to get going around 3,000 RPM.
Thanks!
Thanks!
