boost leak? car dies past 4000 rpm Help
D1JL
7000 Post Club
U.S. Navy Veteran
SFV, So.Cal.
Drivers side pipe from intercooler blew off. Gotta remove bumper and tighten it down. Any advice to make sure it is super tight? Levels front mount intercooler. Thanks for the help guys.
Actually you can fix this without removing the bumper.
I have replaced ALL the boost hoses without removing the bumper.
You don't want/need to make these clamps SUPRE tight.
Remember that the intercooler end bells are plastic (OE) and you could crack them.
Just tight is ok, then check them in a couple of days.
Dave
rodmoe
wausau
Dave
Good Advice Dave though in this case the LEVELS FMIC has metal ends with metal spacers in the adapter ends of the silicone elbows . But yes the Stock FMIC is plastic and nnot up to Heeman type torque on the clamps :)
Z
Oakland
Thread Starter #23
D1jl. How did you go about replacing them without bumper removed? Did you remove fog grills and lower lip guard and go from under that way.
D1JL
7000 Post Club
U.S. Navy Veteran
SFV, So.Cal.
I admit I was referring to the OE or mountune intercooler, both of these I have worked on.
Yes when replacing the intercooler I had to remove the bumper.
However later I installed the complete set of mountune boost hoses, I did NOT remove the bumper for this.
I was able to reach up from underneath and remove the clamps and hoses.
Dave
rodmoe
wausau
Dave
WOW for a old fart you are rather supple if you can get your creaky old bones to flex like that !! GOOD JOB SIR.. [cheerleader]
