To maximize any intercooler I most highly recommend using some ABS plastic sheet and blocking off any air from going around the IC, sides, top and bottom. It will help a great deal especially since the opening to it is so small, force more air into the areas not in the direct line of air flow, etc......
Looks good though
ABS is my preferred material, light weight, can be molded with a little heat applied, flexible enough to not damage things much in a minor hit, easy to work with, low cost. I buy it in 4'x8' sheets wholesale for $32!
I will post mine up before long, nearly ready to put the front of the car back together after months with the bumper cover, whole bumper several times, off the car. I opened up the whole grill, notched the bumper and added an oil cooler as well as CAI duct inside the grill which is more than most will want to do but you can open up more of the grill and consider an oil cooler if having heat issues and want to try not running a bigger radiator, etc....I did all my mods as no radiator available yet.
I also vent some of the air from the lower section of the IC I have out below the radiator so less hot air is blown into it to help engine cooling.
Also for cooling the stock oil to water cooler is nice to warm up the car on cold days faster but then adds more stress to the undersized radiator when driving hard in the heat.
Good day
Rick
Looks good though
Good day
Rick
