I just wanted to give a quick update on my setup for those who might go down the path of a BBK. I ended up going with a Wilwood kit specifically for the FiST so I could use my factory wheels. When I ordered the kit I also got Spec 37 rotors, Polymatrix E pads, and an extra set of rotor hats so I can have separate rotors and pads for street vs track days.
I installed the kit about 3 weeks ago and have put both the street and track setups through their normal use. I'm up to about 1,000 miles total.
Street setup is great. The BP-10 (?) pads and blank rotors work well without a lot of dust and no noise. Initial bite with the pads is great. 100% happy with kit for this use and it looks great, filling in the wheels a bit better. My wife said the brakes look 'cute', so there's that.
The track setup got put through its paces yesterday at Oregon Raceway Park. I'm a member there now so it was an open track day where I got to put in as many laps as I wanted. I went through nearly 2 tanks of fuel and the car got a workout!
Note that the car is completely stock aside from the BBK, Boomba deflectors for the brakes, lighter wheels and 340 treadwear tires. I ran the Polymatrix E pads with stock rear brakes with Hawk HP+ pads. There was really no thought process on the rear pads--just what KNS recommended last year with DTC-60 from pads on stock brakes. Here are my thoughts on the setup...
-Polymatrix E pads are have a ridiculous initial bite when cold. I'm too lazy to change pads at the track so I deal with my track setup on the 100 mile drive to/from the track. If you're not paying attention the bite will...well...bite you. Not good.
-The pads are also a bit too aggressive with some heat in them. It took a couple sessions to get used to how touchy they are. Apply the brakes too hard and ABS lets you know. I had an ass puckering moment when I was too heavy footed at the end of the straightaway at about 95 mph.
-Heat wasn't any issue at all but admittedly air temps were on the cool side at only around 65 for a high. I used heat strips on the calipers and they barely registered a change. That was a welcomed surprise after dealing with repeated overheated brakes at the same track on my '18 STI even on cool days.
-Front to rear brake balance isn't very good with the rear brakes hardly doing anything. Not really surprising as I didn't think they did enough even with the stock brakes.
Overall, I'm happy with the setup for my mostly stock car. I need to do some tweaking to get things dialed in better. Maybe I'll do the Gold Coast rear rotor upsizing kit with the factory calipers to get more from the rear brakes. I was also talking to an instructor at the track who runs Minis and was using his daily driver with Wilwoods yesterday. Surprisingly he was using BP-20 pads and they worked great for his Mini with similar power and weight. I might have to try those or a similar less aggressive pad if I continue to dislike the Polymatrix E's.
